Page 1 of 3 123 LastLast
Results 1 to 12 of 31
    Advanced Member Drew's Avatar
    Feb 2006
    Blue Mountains, NSW.
    833
    Hand brake adjustment
    I've noticed my hand brake travel is now very large after 1000km. Other new cars I've owned had a small change in hand brake travel but none as noticeable as this.
    It's not a show stopper, I'm just curious what other owners have experienced.
    First service is next week, I'm sure they'll fix it then.
    Cheers all,
    Drew.
    Jul 2006
    Melbourne, VIC
    554
    what happened Drew? Have noticed same thing on ours
    Cheers, Nige
    Feb 2006
    833
    G'day Nige,
    They fixed it up at the 1000km service, but I've now done 10,000km and it fairly loose again.
    I'm about to do the 10,000km service myself this weekend and that's one of the things on my list.
    I suspect it's the result of the initial cable stretch combined with the fact that the handbrake operates separate drums in the hubs.
    How many km have you done?
    Drew.
    Jul 2006
    Melbourne, VIC
    554
    700
    It seems to only apply pressure in the last 10 degrees of movement. Wil get them to adjust at 1st service.
    Administrator Piggy's Avatar
    Feb 2006
    ADL, SA/ BNE, QLD
    4,716
    Blog Entries
    4
    Same same, they actually told me at the 1000 that they had done mine as they stretch.
    Guest
    Handbrake travel
    I have also had the problem of excessive handbrake travel, after having only 800Km on the odometer the handbrake was actually at the end of its travel and the brake wasn't fully applied!
    I have a very steep driveway and I was lucky that my wife and I are both in the habit of leaving it in 1st gear as well as using the handbrake.
    I remembered a trick from the past and I was able to make an adjustment myself by travelling in reverse and then applying the brakes. I did this several times in a row and I was able to change the travel back to where the handbrake was working again.
    This is a trick from older drum brakes that would have a ratcheted adjuster in the drum that worked to take up slack from wear of the pads .
    I now have 1300 km and no further problems. Try this and see if it works for you.
    Aug 2006
    Gladstone QLD
    276
    Same here. Mine wasn't much chop from new when i picked it up. Got them to adjust on first inspection service made it a bit better but not great.
    2006 TD Grande
    ARB Winch Bar. Rallye 4000's
    GME TX 3400
    BF Goodrich 265/65/17
    Nov 2006
    Dorset England
    9
    mines 3 years old and done 50000 miles every time Toyota service it (10000 miles ) they tighten the handbrake and it seems to stretch in a 1000 miles or so. This is my first Toyota so I thought it was just one of those things. I've got discs on the back will the reversing trick still work?
    Feb 2006
    833
    Anyone else tried the reverse and hitting the brakes trick? I'm gonna try it as soon as I knock off work. Might grab the factory manual out and have a look.
    Whilst on the subject, can anyone explain the logic behind the drum brakes for the hand brake? Why didn't they just use the disc like most other vehicles?
    Drew.
    Aug 2006
    Gladstone QLD
    276
    Didn't do much for me, maybe i didn't do it right.
    2006 TD Grande
    GME TX 3400
  11. #11
    Feb 2006
    833
    Looking closer at the factory manual and I can't see how the reversing trick would adjust these brake shoes. There is an adjuster wheel in the back of the drum.
    BTW, mine have been adjusted by two different Toyota dealers and the adjustment is out again.
    I hope to get some time tonight to pull the covers off the centre console and see what is going on.
    Drew.
  12. #12
    Advanced Member Strahan's Avatar
    Feb 2007
    Port Douglas, FNQ
    562
    There is an adjustment inside the rear drum as well as on the cable in the centre console. the adjustment should be done at the drum. becareful if you do it at the cable as it is not hard to break of the top of the adjuster nut.
    Its in the drum as it holds a lot better than trying to squeeze the pads on to the disc.
    2005 GXL With most of the fruit!
    Our travels; www.anotherbeautifulstretch.com
