D.I.Y Windscreen wiper jets upgrade
    My '06 Hilux wiper jets are in. I ordered them this morning when I dropped the rig off for it's service. When I picked it up there was a big smile and, "Since we had the car we fitted them for you - no charge".
    They also did the slip joint and checked up that all the recall items had been done. The brake master cyclinder inspection hadn't been done so they did that and replaced the 'O' ring - just in case.
    All ready to go.
    T minus 3 days
    Chippy
      $42 for the jets. $13 for a set of 8 clips. Nix for the fitting.
      They stuffed 4 of the clips taking them out - so I've still got 4 spares
      You can't really see any difference looking at them ...
      But you can really tell the difference when you fire them up .. what a brilliant upgrade !
      Thanks Matt.
      The pic is not quite as effective at night ops:
      Chippy
        Originally posted by Richo
        I had my Prado in for the 80k service on Tuesday (ouch!)
        what was the damage out of curiousity Richo? mines due for the 80k...
          Well done Matt, I got a new company hilux the other week and noticed the jets, but it never crossed my mind to try and retro fit them the the prado.
          I wonder if work will belive that someone stoll the washer jets aswell as the bonet scope?
          Glenn
          2012 GX TD 150 with long mudflaps - [url]http://www.pradopoint.com/showthread.php?23370-Yota-s-150[/url]
          1996 GXL TD 95 with no mudflaps (sold) - [url]http://www.pradopoint.com/showthread.php?12402-My-Truck-quot-Build-Up-quot[/url]
            Chippy
            That's scarily like my the view i get when i pull up outside.... accross the bonnet of an 03 prado... at the back of an white astra hatch...
            any chance there's a part number for the water jets?
              Part number for the jets that I got was 85381-0K010
              If you are careful, you can get the bonnet clip out without breaking them. You'll notice two tiny dots on the outside of the flat plastic. These just happen to line up with the bits on the shaft that need to be squeezed in before you pull them out. (Not sure about the choice of words with squeezing shafts etc but hey!)
              I drive hire cars for work and notice a few of them starting to use these. The Mitsubishi 380 uses them and the Toyota Aurion does too.
              Richo
              [B]2011 KDJ150 GX[/B]
              HID low & high beam upgrade
              Polaris Satnav with reverse camera and Bluetooth
              Outback drawer system
              [B]2012 KDJ150 Kakadu[/B] HID high beam...mod list being slowly ticked off
                Now that's a worry. Can you double check and make sure you're not pulling up out the front of my place :lol: :lol:
                or is it a case of ... Great minds think alike !
                Chippy
                  Chippy
                  yeah i'll run with that!
                  edit: it's probably a bit far to "accidently " end up in a garage 4000k's away... that would be one hell of a bender for that to happen!
                    ordered a set of these today, supposed to be able to pick them up monday!
                      should i have bought some other clips also? i've seen mention of them..
                      edit: that was pretty descriptive wasn't it! but i'm sure those who have made the changes hopefully know what i'm talking about!
                        McBain, You only need the clips if you break them.
                        There are 8 of them .
                        Tried to get the part no for you but the clowns at Toyota said they were not allowed to give out part no.
                        what a joke, all this secrecy for a $2 clip.
                        I had mine fitted by Toyota this morning, and they broke one clip, but said they would fix under warranty.
                        Big deal as I think they are only a couple of bucks each.
                        Toyota bloke who did the job remarked on how much better they are than the standard, and this is obvious once you use them.
                        Pedro
                        Pedro
                        2007 D4D Auto
                          where do the clips fit into the picture?
                          holding the bonet lining to the hood? or the washer pipes to the hood?
                          just so i can keep an eye on them when fitting!
                            The clip that broke on mine was on the bonnet lining.
                            There are 9 of them.
                            Pedro
                            Pedro
                            2007 D4D Auto
                              too easy,
                              cheers!
                                it's a cracker, i would rate it up there one of the best things for this car!
                                $50, 10 minutes, 1 clip sacrificed and a bit of skin missing. They are installed!!!!
                                can't freakin beleive how awkward they are to get to though! they obvoiusly never intended on them being changed!
                                edit: my poor spelling!
