Results 1 to 11 of 11
    Jan 2008
    Adelaide
    7
    Prado CD/Radio Removal ??
    Hi Guys
    Hope I'm posting in the correct section here, I'm new to the forum,I Have a Prado GXL D4D 2007 model Ive just got a Blueant Bluetooth Handsfree Car Kit, And need to gain access to the rear of the standard fit CD/Radio, to connect a wire on to pin number 14 ( Mute Connection ) to install it.
    The question is guys How does the radio come out... Is it the aluminium side strips that have to come off first either side of the radio, carn't find any hidden screws anywhere that hold them on so i presume they are on clips, if so do you start top or bottom ??
    Cheers Guys
    Keith
    Addicted PP Member
    Jul 2007
    Alice Springs, Northern Territory, Australia
    2,724
    Re: Prado CD/Radio Removal ??
    Quote Originally Posted by shaz710
    Hi Guys
    Cheers Guys
    Keith
    Yes Keith they are just clip ons and they are plastic not metal. Just start near the seat and gradually ease them out once you get them started they come out pretty easily. Same goes for the two side stips with the vents in them, just need to reach behind and disconnect the wires to the switch and seatbelt inidicator.
    Mcbain has a pretty good write up on his website:
    http://www.hgfs.net/4x4mods/0710head...10headunit.htm
    Roll on the 2010 Pradopoint GTG
    Pradopoint GTG website:
    http://www.pradopointgtg.com (final website location on its own domain)
    My Weather Station In Alice
    http://www.alicespringsweather.a60.us/
    My photo website:
    http://centralian.redbubble.com/
    http://i78.photobucket.com/albums/j1...y72/logo-1.jpg
    Jun 2007
    Wagga Wagga
    280
    Gday Kieth, there are a couple of posts showing pics etc on how to pull the stereo out have a bit of a search, but basicly give the shiny bits each side of the gearstick a yank upwards, then gently pull the panels with the airvents out from the bottom of the panel first, the ashtray area then just pulls off, this will then give you access to the bolts that hold the stereo in, as you said everything is clipped together except the actual stereo. Oh and the white plastic connector is missing the actual spade that connects to the stereo pin so you will either have to source one or solder a wire to the pin or some other method.
    Jun 2007
    Wagga Wagga
    280
    beat me mav ! im a slow typer
    Dec 2007
    REDLANDS
    63
    Easy as really
    Check out "Head Unit Upgrade" elsewhere for Pics and details but basically lift up silver trim either side of the Gear lever first (some force required first time) then remove silver trim either side of Radio (pull gently from bottom first).
    Dec 2007
    REDLANDS
    63
    Mav
    You beat me as well.
    Your dedication is appreciated.
    Jan 2008
    Adelaide
    7
    Fantastic guys
    Really appreciate your quick replys, what a great forum, Can anybody also recommend a good reverse camera with a small LCD display ??
    Whats the wireless ones like anybody used them ? Wondered if they are any good.
    Many Thanks
    Keith...
    Addicted PP Member
    Jul 2007
    2,724
    Fantastic guys
    Many Thanks
    Keith...
    I do not have any experience with the small wireless packages but they would be my pick if I were to go that route. Most of us have in dash screens that we can attach a camera to.
    My photo website:
    Jan 2008
    Adelaide
    7
    Quote Originally Posted by mav
    Fantastic guys
    Many Thanks
    Keith...
    Yes I'm also looking into an aftermarket upgrade too, some of the photos Ive seen on here look really cool
    Jan 2008
    Adelaide
    7
    Hi Guys
    Next problem....... Ive got the radio out and guess what pin Number 14 Tel Mute is missing from the loom plug !!!!! Good old Toyota
    Any one know where i can purchase a pin with a short piece of wire attached to it to push and lock into the standard plug for the back of the radio.
    Many Thanks
    Keith
  11. #11
    Jun 2007
    Wagga Wagga
    280
    Kieth, as I mentioned above it is a blank spot, slackos ! I havent chased down a pin, but im sure your friendly local yota dealer would help out. With mine, I unplugged the connector and soldered a small wire to the pin on the stereo then plugged the connector back in over the soldered on wire, looks like it is done with the little pin, unless you look real close :wink:
