DIY Suspension install ?
  • A big thanks to this site and amts also chippys posts n pics on doing DYI suspension install. I used pretty much all tips as above but disconnected rear sway bar link to help lower rear diff even more to get springs in.The Mrs was a helper for the fronts, So i guess i could take her out for dinner with the money saved on installation.Cheers Steve
    • Originally posted by getspeed69 View Post
      C'mon man, that's just silly talk, spend the savings on more mods
      • You have a valid point Andrew more mods on the way
        • Just as a thought...how many folks have a hilift jack.....
          Make a couple of addapters and theres your super heavy duty spring compressor
          • Hi All
            Just stumbled across this informative tutorial for strut assembly and install.
            https://youtu.be/rZ8eoJu1ELY
            https://youtu.be/e-7ysiGblyc
            Then the rear
            https://youtu.be/oxV-CAAfrgg
            Hope the link works and is helpful for some one.
            Troy
            foxclan
            • Finally got around to installing my lift kit yesterday.
              I used the no spring compressor method as per Amts suggestions and once the factory stuff was out it was fairly simple.
              I fear i may have tightened the top strut nut too much. as I can't get a torque wrench on it in situ.
              how do you gauge the tension on the top nut of both the front strut and the rear shock?
              Is it just once the bushes are a bit squished and the nylocks have got at least 3 threads through the nut? or is there a more technical way to it?
              • Originally posted by woodwormm View Post
                Until the nut bottoms out on the shoulder, basically when it's tight.
                • Originally posted by adrian5800 View Post
                  cheers for the reply, in all the diy threads i struggled to find this info..
                  I'd best get under there and tweak a bit more.
                  I didn't want to deform the bushes too much by spanner if it was over-doing it.
