Sovereign bull bar fitting instructions
  • Sovereign bull bar fitting instructions
    Hi
    Ive just got a secondhand sovereign bull bar for my 120 and was wondering is anyone has the instructions to fit it.
    I understand the inner skirts have to be trimmed but is there anything more involved than that.
    Wayne
    EDIT.
    OK if you dont want to read the rest of the threads to get the PDF of fitting instructions just follow link below
    https://www.box.com/s/4j3y3ulu3s3il2fggy0c
    amts
    Ninja Poster.
    Re: Sovereign bull bar fitting instructions
    PM sent with instructions
    LC 120 03 GX V6, Bonnet/Head light Protectors, Home Made Draws.Toyota Tow Bar.Cooper ATR 235/70/R17 RE+. Toyota Bullbar with fog light. Navra 150 Spot Lights.
    [url="http://tikarn669.googlepages.com/home"]http://tikarn669.googlepages.com/home[/url]
      Thanks LenGXV6
      Would you know if there is a difference between a GX and GXL bar.
      Regards
      Wayne
        Originally posted by sparksy
        Thanks LenGXV6
        Regards
        Wayne
        The toyota soveriegn bar has little black plastic overiders on the outside of the bar to match the flares on the GXL, Current GX is the same, pre 2006 GX has no overiders as the model did not have flares.
        [b]Rob[/b]
          Thanks Hutch
          Are those that I can see on the photo of your Prado.
          Wayne
            Thanks Hutch
            Wayne
            Yes the black bits on the end of the bar below the flare.
            [b]Rob[/b]
              Sorry LenGXV6
              Opened the PM but didnt get the instructions
              Does anyone else have a set.
              Wayne
                resent via hotmail
                  Thanks LenGXV6
                  Just saw them. Much appreciated
                  Wayne
                    Hi Spark,
                    Did you fit your bullbar? I've just bought a second hand bar for my D4D and plan to fit it tomorrow. Just interested to see if you have any hints for me from your experience.
                    Rgds,
                    Peter
                      Yeh
                      Make sure all the parts are there. I got the instructions from LenGXV6 and it shows a captive nut called a CHASSIS PIN
                      and a large bolt that goes from the front of the bar through the chassis mount. Also a bracket that fits behind the chassis mount and bolts onto the lower chassis.
                      The bar I got didnt have these parts and it looks like I will have to buy the whole fitting kit to get them. My cheap bar doesnt look so cheap now.
                      I got the instructions so if you want them PM me and I will email them to you.
                      Wayne
                        Hi Wayne,
                        I was lucky with mine. The guy who sold it to me included a new fitting kit so I got the lot; Including instructions the chassis pins and fancy bolts. I fitted it up yesterday and didn't need a single visit to Toyota spare parts dept. I think that I really lucked out. The unit cost me $1250.00. One Toyota dealer wanted $2250 and another $2420.00 for a new one. Once you get the fitting kit, my suggestion to you is get someone to help you install the bar. I did it by myself and it took most of the day yesterday. Worked out in the end but it was a bit difficult in a couple of bits. Only have to connect the lights (parking & indicators) that came with the bar. I found the instructions quite easy to follow but if you get stuck just drop me a line.
                        Pete
                          Well I dont feel so bad now.Got the Chassis pins and those two brackets that it each side of the chassis for $60 from Tony's wreckers in Midvale along with most of the bolts. Got the bar from a bloke in Mandurah for $300, so touch wood it should fit up ok. Will fit it next weekend.
                          Wayne
                            Sounds like you got a great deal Good luck with the install
                              Hi, I also have just bought a 2nd hand bar. Apparently it has the full fitting kit, but I guess I'll not know until fittin time...
                              If you would be so kind as to forward a copy of the fitting instructions for me too my email is msimpson at continentalconveyor dot com dot au.
                              Many Thanks
