Page 1 of 3 123 LastLast
Results 1 to 12 of 30
    Oct 2008
    Morisset NSW
    16
    Prado ARB Air Locker?
    Hey All,
    I am toying with the idea of getting a locker for my Prado. Just wondering what your thoughts are??? Should I be looking to get a front or rear locker ? As I can only afford one at the moment. I was thinking front but not too sure.
    Advanced Member GH4wd's Avatar
    Jun 2009
    Cranebrook, NSW
    969
    Re: Prado ARB Air Locker?
    Go for it I say :!: I had ARB put a rear locker in mine & it is fantastic. Check out the trip to Newnes State Forest on July 26th in the trip report section.
    Cheers, Glenn
    Glenn
    2002 GXL 3.4 auto with BFG AT's, Lovell's/Bilstein suspension, ARB steel bullbar, winch, towbar, diff lock, air compressor, GME UHF & AM CB radios.
    Youtube Panoramio
    Advanced Member Yota's Avatar
    Feb 2006
    Dubbo, NSW
    590
    Lockers are probably next on my list
    Was leaning towards a front locker, to save the CV's.
    Ill just do both so i dont have to decide
    Glenn
    2012 GX TD 150 with long mudflaps - http://www.pradopoint.com/showthread...370-Yota-s-150
    1996 GXL TD 95 with no mudflaps (sold) - http://www.pradopoint.com/showthread...-Build-Up-quot
    Wishing I was lost Snaga's Avatar
    Apr 2006
    Brisbane, QLD
    3,301
    I went with a rear locker but the decision was made for me when I blew up the LSD ops:
    Everything I read previous to that was probably directing me towards a front locker but now I think I would do the rear first.
    Up hill... it'll be pushing you up the terrain rather than pulling you up it. So I figure if a car is heading up hill... the rear tyres would have the best chance of solid contact with the ground (with the weight of the car on at least one of them) rather than the front tyres... with less weight and scrabbling for traction.
    That's how I see it... whether it's correct or not... who knows
    Leon
    Optix Photographix
    Junior Member Ron.H.'s Avatar
    Jan 2009
    Salisbury Brisbane QLD
    68
    I would go with the rear if you are only looking at 1at the moment. I couldn't decide either when I got mine so I did both seeing I could afford it at the time. I have had them about 4 and a half years now. The front locker does interfere with the steering a little as well it stiffens up and the turning circle is larger and if on a loose surface on a side slope it tends to crab sideways but the rest of the time it is great for traction on uneven surfaces rocks and so forth. With 2 you are nearly unstoppable if you have clearance.
    Cheers Ron.
    2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
    Feb 2007
    South Australia
    3,092
    Here's an interesting take on locker installs from 4wd Systems in Adelaide;
    (They sell a soft locker so ignore d.)
    Which end should I fit first?
    This is dependent on the vehicle, its existing diff types, the type of suspension system and the model availability. However the front is usually the first choice.
    a. If the vehicle is an IFS (Independent Front Suspension) model then the front fitment will result in the greatest increase in 4WD ability. This is because all IFS vehicles have very limited suspension movement (hence limited wheel travel and articulation) resulting in easily lifted wheels and total loss of front traction. Fitting a LOKKA to the front will solve this serious deficiency. (Pajero, Isuzu, 4Runner, B2600 etc)
    b. If a vehicle has a good quality LSD in the rear, then a front fitment will obviously provide the best total traction ie one locker and one LSD is better than one locker and one standard diff. (GQ)
    c. If a vehicle has a poor quality LSD then the issue becomes less clear and personal preference or ease of installation often become the more important criteria. However one LSD and one locker is still a better choice - if that is possible. (Landcruiser, Hilux, F100/150)
    d. If the vehicle is a constant 4WD then a rear fitment is the easiest and best solution (Landcruiser 80,100 series etc)
    e. A front fitment will actually yield the greatest improvement in off road ability. This is because, most vehicles require the increase in traction (that a locker gives) when hill climbing. Under hill climbing conditions, due to the angle of the vehicle, the rear wheels are carrying a much greater weight (weight transfer) and the front wheels are therefore carrying a lessor weight and tend to break traction very easily. Once one front wheel starts to spin, the other front wheel stops turning and the whole front diff ceases to provide traction. At this point all load is transferred onto the rear as if it were a 2WD and due to the increased load the rear wheels are encouraged to spin and the vehicle stops.
    If you can solve the problem of the front wheels spinning, you have solved the traction problem. Another advantage is that on road there are no changes to normal driving characteristics at all.
    Mick
    Advanced Member jcas24's Avatar
    Apr 2008
    Maitland, NSW
    601
    i did see a comparsion video on youtube a while ago, nolocker -v- front locker -v- rear locker, all tested in the same vehicle. It set my mind on what I thought, front first. I can't find the clip
    2000 Toyota Prado GXL- Gone, but not forgotten...
    '92 Landcruiser HDJ80 4"lift 33's
    '91 Surf LN130 coil sas, 4.8s, 35s
    '12 Jayco Eagle Outback
    Apr 2006
    Brisbane, QLD
    3,301
    Interesting... I figured it would be the other way around. (sure glad I put that disclaimer in there :lol: :lol: )
    Leon
    Optix Photographix
    Nov 2007
    Alice Springs NT
    478
    Yeh go the front first, the LSD helps a little in the back until they get hot. I had a air locker in the rear in my Vitara for a while but I found myself more in trouble than it was worth as I would end up in a nastier position due to the locker. The front will help you climb alot better, but loss your steering. Its the only negitive, Zook.
    97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
    Advanced Member xlr8_87's Avatar
    Sep 2008
    Melbourne, VIC
    587
    last time I checked ARB only made a rear locker for the 90 series? or at least there was only a rear locker for the 96?
    <Rob>
    '93 HZJ80 - DTS Turbo/Intercooler, 35's, Autocraft super flex 3" lift, Part-time 4WD, ARB Winch Bar, TPMS, EGT, DVD, Raslarr Rear Bar, Raslarr Sliders/Scrub Bars
  11. #11
    Feb 2007
    South Australia
    3,092
    1996 to 2003 front locker- 7.5" 10 bolt IFS - Fits all ratios- Part No RD90
    Mick
  12. #12
    Jun 2007
    Greenbank
    199
    If the Prado was a part time 4wd instead of an awd mine would already have an auto locker in the front. I will be doing both but I will admit I am not a fan of air lockers in the front of an IFS. They put a lot of strain on CVs unlike auto lockers that can allow one wheel to spin faster reducing the pressure, but seeing as its an awd you dont have much choice. If you can only go one go the rear although I believe that the front makes more difference :wink:
    Trail Toy - TJ Wrangler with some mods and some bling
    Wifes Daily and Tourer - V6 120 Prado, some mods wife wont give me the keys.
