Fitting Electric Brake Controller
  • Fitting Electric Brake Controller
    The first accessory fitted my new LC150 Prado was the Tekonsha P3 brake controller, this took a great deal of planning due to limited positions available and the multiple air bags fitted to the Prado.
    We decided on a position near the drivers L.H. knee well away from the knee airbag and with easy access to the controls. The P3 could not be mounted under dash as the dash is very low and the driver would not be able to see or operate the P3.
    Notes: All cables were run on passenger side as a/c is in RH Rear. We picked up stop light from rear trailer connection and did not tap into any stop light switches. When laying the cables use the inner track leaving the outer tracks for battery cables described later.
    Regards
    Derek from ABR
    Prado 150 GXL - V6 Auto, ABR-SIDEWINDER Dual battery System, Tekonsha P3, 50mm Lift kit - King Springs & Bilstein Shocks, Polyair Bags, BFG 275/65R17 Tyres, Milford Cargo Barrier, ERPS Extreme use 10 coupler rust protection, Rhino Rack, Factory Towbar, ABR-SIDEWINDER fridge/freezer, ABR-SIDEWINDER compressor and PSV deflators, Twin Drawer system, Fridge Slide, Twin 23L water tanks, 80W Solar Panel, Hot Water Shower, ARB Awning, Toyota Seat Covers, ARB Winch Bar, Warn XD9000, HID's, Snorkel .
    My website: [url]http://www.sidewinder.com.au/[/url]
    Re: Fitting Electric Brake Controller
    Great install Derek,
    .....and welcolme to Pradopoint.... great to see someone with your skills and knowledge on the site.
    [color=#0040FF]Rob[/color]
      Hi Derek
      Congrats on the new LC150 Mate and welcome to the Forum.
      Look forward to the build up of your new Vehicle.
      Cheers Troy
        Hi Derek,
        Welcome to the site, a nice clean fit up, I will be installing a P3 into my mates new 200 series and will probably use the same position, depending on clearance etc.
          Any reason why you didn't use the other bracket to mount the controller? It would sit more flush to the dash?
            I will remove it when not in use as I only tow about 6 times a year.
            Regards
            Derek
              Hi Derek,
              I can't really tell from your photo's but how close is the controller to the Knee airbag? I am not sure how it deploys but is there any risk of it catching on the controller were you have it mounted?
              Cheers Neil
              White 2013 GXL 79 series dual cab, ARB GVM Upgrade, ARB Delux winch bar and scrub bars, GME TX3440 and much more to come
                Originally posted by two+four
                Hi Derek,
                Cheers Neil
                Hi Neil
                No chance as the knee air bag exits from a slot about 100mm below the controller, the controller is also mounted about 100mm to the left of the slots end point.
                I made sure of this as the last thing you want is the air bag to launch a P3 into your knee. ;-)
                Regards
                Derek
                  Derek, did you run the blue wire fromt he Tekonsha all the way to the trailer plug and jump it to pin 5 - or did you utilise what looks to be existing wiring with the factory trailer plug?
                  dan
                  Dan - Prado 150 GXL - now for sale
                    dan
                    The harness now available here: http://www.sidewinder.com.au/page190.html connects to the factory harness at the L.H. rear.
                      does it connect with anything other than a simple join? like a plug to adapt into an existing factory module. it sounds like it is just a wire kit from what i can tell on that link.
                      dan
                        dan
                        You need to connect the two wires with the joiners supplied.
                        As there is already at least 3 manufacturers of tow-bars there is no way we can standardise a plug. You will find that the blue wire is just loose anyway, it is only the red stop light wire you need to join into.
                          I went to an Auto Electrical shop today to have my Prodigy fitted and they said because the knee air bag deploys out and UP they would not fit it where you guys are showing in the photos above. He said if something happened and the airbag didn't deploy properly then I could bring it back on them. I can see where they are coming from so I have ordered a remote RedArc one which they are fitting tomorrow.
                          My concern is warranty so I'll go with what they say.
                          2009 Prado Kakadu silver Auto with towbar. Redarc dual battery system, Redarc remote brake controller, Airtec snorkel, GME remote 3340 VHF CB radio, 12v heavy duty plug in cargo area, anderson plug to rear, ARB air compressor, Jayco swan outback 2007.
                            G'Day All,
                            My first post, Picked up my diesel GXL 150 this week.
                            Firstly thanks to all the regular posters. Reading your experiences has helped pass the time during the long wait for the new 150.
                            I had the factory tow bar fitted and now need to add the break controller. I like the (hidden) look of the RedArc remote unit, but I'm concerned about the no proportional breaking. I'll be towing a 1200kg (when empty) A-van Ray 14'. Does any one have any experience and comments? I see a few have been added according to other posts. The P3 would be a second choice but only if the no proportional breaking is an issue.
                            I'm also a bit unclear as to the use of the (very small) blue wire in the R/Left compartment from the end of the factory harness. Are people using this or rewiring direct to the plug with something bigger.
                            Thanks,
                            Mark,
                            VK2JMA
                              "I'm also a bit unclear as to the use of the (very small) blue wire in the R/Left compartment from the end of the factory harness. Are people using this or rewiring direct to the plug with something bigger."
                              Hi Mark,
                              I wired my Prodigy brake controller in using the blue wire you refer to, see here, viewtopic.php?f=47&t=8040#p112598 , and the wire is not as flimsy as you may think, it's good for at least 15 amps and is fine for my twin axle ( 4 magnetic brakes) 2 tonne caravan. With a single axle (two brake unit) campervan you will have no problems using this wire,...just make sure you make good solid connections.
                              Rgds, Rob
