Results 1 to 8 of 8
    May 2007
    South West Vic
    160
    Roof rack pole carrier
    Does anyone have pvc attached to their roof rack or roof bars to carry poles and fishing rods and the like? Ive got pvc pipe etc to use but im just unsure how i will attach the pipe clamps to the roof rack. The bars, Rola, have an optional clam for $30 or $40 but i was wondering if there is a simple do it yourself option ? I think the Rola ones will have a bolt a piece of flat that will clamp up inside the bar channel, i dont think i could replicate that so well though??
    2000 TD RV
    Bent sidesteps
    The odd scratch and dent
    Advanced Member two+four's Avatar
    Oct 2008
    Port Kennedy, WA
    663
    Re: Roof rack pole carrier
    Quote Originally Posted by slug
    Rhino rack do an L bracket that was designed for tail lights. It used to come for the sports bar and HD bar but is now only available for HD. If you get different channel inserts you can use this
    http://www.rhinorack.com.au/AccSubCa...et_352_24.aspx
    I used a set on each side of my cross bars to mount my Awning and PVC pipe before I got my Tracklander. Unfortunantly I have already given them away. You can see it early on in my build thread.
    They also do an eyelet pack you could buy one of them and make the L brackets your self.
    Neil
    White 2013 GXL 79 series dual cab, ARB GVM Upgrade, ARB Delux winch bar and scrub bars, GME TX3440 and much more to come
    Senior Member QUICKY's Avatar
    Jul 2007
    NEWCASTLE
    413
    Rhino also make this clamp for your pvc tube
    http://www.rhinorack.com.au/AccSubCateg ... 51_44.aspx
    it's the clamp i use on my racks but i'm not familiar with the set up on your Rola racks
    Avid PP Poster! foxclan's Avatar
    Jul 2008
    Adelaide, SA
    1,259
    I picked up some plate nuts (uni strut nuts) from an electrical wholesaler close to work, M8, M10 about $1.80 each
    The nuts come with a spring attached which is easily removed, other than that they are the same as the Rhino plate nuts.
    Then I got some M10 collared eye bolts @ $3.30, and 40mm x 40mm x 3mm zinc plated washers @ $0.30 from United fasteners.
    The square washers look neater than the ones in the Rhino kit.
    I will use the M8 plate nuts and washers to mount Brodies shovel and rod tube to the Rhino H/D bars
    cheers Troy
    May 2007
    South West Vic
    160
    Thanks guys, foxclan, you wouldnt have any pics of your set up would you?
    2000 TD RV
    Bent sidesteps
    Jul 2008
    Adelaide, SA
    1,259
    Slug sorry for the non reply mate.
    I will be picking up the shovel holder brackets tomorrow from the powder-coaters.
    I am midstream into a fridge slide build up, then to tackle the rod tubes.
    Currently on Fleabay are Rhino Roof rack/ Bar 100 mm PVC pipe Holders up for grabs.
    Not sure if the will fit your bars but Rhino RRP. is $49.00 for the three P/N BC3
    Bidding's at $23.50 with 13 hours to go.
    Cheers Troy
    Junior Member shawsie's Avatar
    Mar 2007
    Brisbane, QLD
    33
    Just some advise about the pole tubes.... please make sure you have added protection/support in the front end of the tube. I had some 19mm deck hardwood lying around so I rounded a piece off and then glued it into the end-cap. i then glued AND screwed the end-cap to the pole. this will stop the poles flying out of the pole tube going over pumps & breaking - to a very large degree. Sorry if this is common sense, but it was done through experience
    FJ Cruiser - you know you want one......
    Feb 2009
    Biloela, QLD
    303
    Quote Originally Posted by shawsie
    Any pics?
