Scangauge on the 150 series
    Re: Scangauge on the 150 series
    I ended up putting mine on the right hand side part of the dash next to the A-Pillar speaker. I stapled the velcro to the dash mat so that it would lock on and ran the cable down the inside of the door jam rubber so that you do not see it. My wife could not see the fuel gauge when it was on the steering column.
    Daniel
      i was mainly keen to see if it impacted on the view of the instruments.
      god i like the look of that VX instruments..
      Dan - Prado 150 GXL - now for sale
        Finally got round to re installing my scangauge from the Terracan into the Prado. Easy job works OK. I was looking for the book of words to work out what a couple of the gauges might be and could not find, so went on line. Does anyone have the Xgauge version with the programmable gauges? I would love to create a gauge to view the auto transmission temp when towing. Hard to tell on the web site whether there are programming codes for this. I suspect that seeing the computer in the Prado monitors this via a high temp alarm in the dash, that you should be able to see the temps in the gauge as per the coolant temp, just need the programming codes.
        Mike
          Hi...
          I've recently received an email from Scangauge in the US re: Auto Transmission Temps, etc.... This is their reply:
          Hello Rob,
          Thank you for your inquiry. Unfortunately, our engineers are still in the process of testing new Toyota transmission temperature codes. Currently, transmission temperature is only available for Ford, GM and some VW vehicles via the X-Gauge feature. The X-Gauge comes standard on the ScanGauge II and allows you to program extra gauges into your unit for your vehicle. Our engineers have found two codes in order for the ScanGauge II to display transmission temperature for Toyota vehicles, however they are very experimental so there is a possibility that the codes may not work.
          TXD: 686AF101B4
          RXF: 044105B4
          RXD: 2010
          MTH: 000703E8FFD8
          NAM: TFT
          or
          TXD: 686AF101B4
          RXF: 044105B40000
          RXD: 2808
          MTH: 00090005FFD8
          Please let us know the results of the these codes for your vehicle and if you have any further questions.
          Regards,
          Leah O'Campo
          Director of Communications
          Linear Logic
          1.888.433.5664
          Now, I recently tried these codes that they suggested,but without any luck as all I got was a blank space where the reading was suppose to be..... looks like it's a no go.... unless they come up with a solution down the track...... bit of a bummer as this was one of the main features that I wanted to work
            Thanks, I think this one of those things that we just keep and eye on as I am sure they will come up with something eventually. It would sure beet buying a dedicated transmission temp guage for over 200 bucks.
            cheers
            Mike
              I have one of my gauges pointing to MAP, which is supposed to be manifold pressure. Given I have a D4D engine, I am wondering what this is actually reporting? The gauge responds from 70 odd up to 150 odd depending on throttle use.
              Mike
                I don't think that MAP is right - MAP is for naturally aspirated engines. You should change that to BST, which is for turbo charged engines. The BST reading will show how much boost pressure is in the inlet manifold.
                You can find this information from the user manual here:
                http://scangauge.com.au/support/pdfs/SGIIMan601.pdf
                Go to bottom of page 17.
                  Hi Rob,
                  Your wish may have come true. Here is a snippet of information which may be of use to you. If you have an early ScanGauge II with firmware 3.17 or earlier, the information below will NOT work. You will need to either buy a new ScanGauge II with the 4.02 or later firmware or send your old ScanGauge II in for a board upgrade to the newer firmware (it costs about $50 for this upgrade).
                  The following information was recently posted on the "Ample outdoors" website.
                  http://scangauge.com.au/?page_id=338
                  August 16, 2011
                  Automatic Transmission Temperature X-Gauge for Toyota Vehicles
                  Below is an experimental code for Toyota vehicles. We have confirmed this works in the Landcruiser 200 Series Diesel using v4.02+ SG2 firmware and we have unconfirmed reports that this code will work on the 150 series Prado diesel and 120 series V6 petrol using a v4.02
                  firmware ScanGauge2.
                  We are unsure if this X-Gauge requires ‘v4.02 - onwards’ to work or if it will work on any XGauge enabled ScanGauge2.
                  TXD: 07E121D9
                  RXF: 032100000000
                  RXD: 2808
                  MTH: 00010001FFD8
                  NAM: TFT
                  Please report Toyota vehicle compatibility to [email protected] with the following
                  information.
                  Vehicle Make: Toyota
                  Model:
                  Manufacture month and year:
                  Fuel Type:
                  ScanGauge firmware:
                  ATF X-Gauge works (Y/N):
                  Brett Alexander
                  [email protected]
                    Guys where's the OBD socket located on the 150 please ?
                    Ross
                      Behind the air bag under the steering wheel column towards the floor. Hope this makes sense.
                      Johno.
                      [CENTER][SIZE=2][B][COLOR=blue][COLOR=blue]150 GXL 2009, T/D Auto [/COLOR][/COLOR][/B][/SIZE][/CENTER]
                        Ross
                        Get your head down and have a look behind the panel in the vicinity of the fuel door and bonnet release handles under the dash.
                        REV
                          Guys....
                          With your SGII, what gauges do u have up on the display all the time as u are driving along?
                          I've got the following:
                          • Water Temp
                          • AVG economy
                          • TPS (not sure what advantage this is)
                          • Speed
                          (mine doesn't or can't give me the ATF Temps)
                          What do others have up on their display?
                            Transmission Fluid Tempature (had to get and enter the XGuage code for this)
                            Water Temp
                            Speed
                            Battery Voltage
                            I may still have the codes for this, from memory I downloaded them from the Scanguage site.
                            It tells you in the booklet how to enter them.
                            The transmission shop that I go to, had never seen the scanguage before and they are very impressed with it & have bought some for themselves.
                            REV
                              Water Temp
                              Speed
                              Battery Voltage
                              REV
                              Rev... if u can list what u entered that would be great. What version of software have u got on your SGII? (ie v4 or older? how old is your unit?)
                              cheers....
                              rob
                                cheers....
                                rob
                                I have v4 and have had the scanguage maybe 8 - 9 months.
                                Try these one of these sets of codes. Refer to your booklet on the procedure and it's easy!
                                Toyota TXD RXF RXD MTH Notes
                                ATF Temp A 07E121D9 032100000000 2808 00010001FFD8 AKA – “Alpha” or “Original”. Firmware v4.0+. Confirmed in 200 Series Petrol and Diesel, 2007 120 Prado D4D & 150 D4D Series Prado
                                ATF Temp 1 07E021D9 032180000000 2810 0003004DFE70 Firmware v4.0+. Confirmed in 2005+ V6 Prado and USA 2008 FJ Cruiser (torque converter sensor).
                                ATF Temp 2 07E021D9 032180000000 1810 0003004DFE70 Firmware v4.0+. Confirmed in 2005+ V6 Prado (Oil pan sensor)
                                I got them from http://scangauge.com.au/?page_id=338
                                REV
