Page 1 of 6 123 ... LastLast
Results 1 to 12 of 71
    Avid PP Poster! Whitey's Avatar
    Mar 2009
    Brisbane
    1,064
    Low 1000 rpm shudder/vibration
    Pradopointers,
    Have searched through the driveline threads and haven't found a similar description of my problem....
    In my 06 GXL 4l auto, I am getting a considerable low rpm shudder at around 1000-1100rpm, quite noticeable going up a slight incline at around 60km/h, and still noticeable on flat streets driving at 60km/h, so it's getting quite annoying driving around the city !
    It feels similar to when you are driving a manual car in too high a gear uphill and the driveline starts to vibrate.
    My 05, also a 4l auto didn't do this.
    There are a lot of potential causes here, wheel balance, harmonic balancer, broken engine/gearbox mounts, uni joint, dirty injectors etc etc.
    Has anyone experienced a similar low rpm shudder/vibration to this and found an obvious cause ???
    Thanks for your input !
    Whitey
    2006 GXL petrol auto. ARB deluxe bar x3 HID IPF's, ARB alloy roofrack, ARB awning, BFG A/T, Safari snorkel, Piranha breathers, Pacemaker extractors, Bilstein D563-M2 433-570mm with H&R 675lb/in, Ironman 45682FE 383-618mm with Dobinsons 487, Firestone kevlar 60psi airbags, 30mm extended Roadsafe links, AMTS bashplate and recovery points, ABR Flyer with Powersonic AGM.
    Re: Low 1000 rpm shudder/vibration
    I had a low RPM shudder, but only really noticed it while idling. It was 2 x injectors
    cheers
    December 2007 Prado GXL diesel, Option Pack with traction control, rear airconditioning and curtain airbags. Lovells Springs and Bilstiens shocks, snorkel, front recovery points,
    ARB Bar with fog lights, ARB second battery system, sandgrabber mats, Pirelli ATR Tyres,
    Sep 2007
    Wagga Wagga, NSW
    552
    Some of your suggestions could possibly be eliminated by driving at the set speed/engine rpm.
    If you suspect speed, then try that speed in another gear & see if it happens then.
    If you suspect rpm, then does it occur at the same rpm but in different gears...
    It is possible that it is a resonance meaning that it has to be a set speed & a set rpm, but if that is the case perhaps that will assist in eliminating what it can't be.
    Does it happen when the drivetrain changes from under engine power to being pushed by the car (uni-joints possible here). Does it modulate at all in this situation?
    Does Turning the steering wheel make any difference?
    Just a few ideas....
    Richard
    2011 GXL TD Auto Prado Silver
    Mar 2009
    Brisbane
    1,064
    Hey guys,
    Thanks for your replys !
    After a bit more testing, I can feel the same shudder/vibration occurring when the car is in P or N.
    I couldn't notice the shudder/vibration at any other speeds, only in D, when going 60-70km/h up a slight incline, it always kicked in around 1100rpm.
    The shudder/vibration is considerably more noticeable when going up a hill, same applies if the car is in N or P while sitting on a hill.
    Clearly, something is causing an imbalance in the engine if it is occurring while in N or P, which still leaves a lot of possibilities, engine mounts, injectors, spark plugs etc etc.
    At lower or higher rpm than 1100, the shudder/vibration goes away. ...although I suspect at higher rpm it is masked, I can feel the vibration come on again when I drop off the accelerator from high rpm.
    Any ideas from the pradopoint database ???
    Whitey
    Mar 2009
    Brisbane
    1,064
    G'day everyone,
    Today I changed my sparkplugs, and I noticed a big water stain underneath one of my coil packs. The plug was noticeably more dirty than the others, and there was a bit of stain on the end of the coil pack.
    After cleaning it up, and putting in the new plugs, I believe the shudder/vibration I had is now gone. This shudder was like driving on 5 cylinders, clearly under load I was getting a misfire.
    I also noticed an old white corrosion stain underneath the seal on another coil pack.
    Obviously water getting in underneath the coil pack o-ring seal is a big problem. The o-ring itself also has a small pin hole in it which can let water through !
    Clearly this is something to be very aware of for deep water crossings.
    Even though I have a snorkel (and have not done anything deep, I just got the car), I will now be watching around the coil pack o-rings very carefully. Also, I noticed a lot of compression blow through on the top of one plug which hadn't been tightened enough - this could affect the coil pack, so beware of loose plugs !
    I'm surprised that the seal was not made to a better spec, and I will be looking at water proofing this somehow ! ...the pin hole must be to relieve hot air pressure building up, so to hold this hot air pressure, the seal would need to be much better than an o-ring. This is in my mind a serious flaw in the water proofing of the V6.
    Any suggestions for better waterproofing from anyone who has had a similar problem ?
    ...also, for everyones knowledge, apparently the coil packs are seriously bullet proof, they'd wanna be for 185 bucks a pop !
    Whitey
    Mar 2009
    Brisbane
    1,064
    ...woops, posted too soon !
    After putting in the new plugs, the vibration has just moved closer to 70km/h at around 1200rpm, where as before it was closer to 60km/h.
    I found an 'engine misfire' thread in the engine-petrol-120 section, where Dobbo reported a similar problem starting at 1000rpm, and also occurring at idle sometimes.
    Dobbo managed to fix the problem with new plugs, but new plugs haven't fixed my vibration/misfire.
    ...anybody got a clue on this one ???
    Whitey
    Whitey,
    I don't suppose you have an answer for this problem??
    I've got the exact same problem, the vehicle seems faultless otherwise, but I don't want to take it somewhere to hear they have no idea what the problem is.
    If you could let me know that would be great,
    Feb 2011
    penrith sydney or somewhere in oz
    10
    Hi all .
    My prado 07 3LT turbo diesel 6 speed manual has the same slight shudder/vibration problem . I towed a 2 ton caravan for the first time on the weekend twice on different
    occasions going up hill we could first fell the shudder then we smelt what seemed like hot iron/steel ( and no it was not clutch burning smell ) . So it seems traveling at about
    80klms per hr in 6th gear all is good then when i put load on the engine going up hill something is overheating and very slight vibration is felt .
    Has any one had this same problem with a manual .posting.php?mode=reply&f=10&t=8110#
    Mar 2009
    Brisbane
    1,064
    Hey Tuff_Prado,
    Unfortunately I have not found a solution to this very annoying problem. However, it is more of an annoyance than anything serious, I don't think anything is about to break !
    Things I have checked so far.....
    1. Air flow meter (mine was sparkling, gave it a clean anyway)
    2. Fuel filter (was pretty dirty)
    3. Sonicated my injectors (had 2 bad spray patterns)
    4. New spark plugs
    5. Put pacemaker extractors on
    6. Flushed the automatic transmission oil (did smell a bit burnt after 96,000 km)
    7. Checked over the exhaust for loose/bunched up rubber mounts etc.
    8. Spoke to Toyota mechanics
    I have done all of these things in my quest to track down this annoying shudder, and absolutely no difference so far, the shudder is still there.
    I have had 2 Toyota mechanics in the car with me, and they have both felt the shudder/vibration. The Toyota mechanics think it is reminiscent of the "boom noise" that 90 series Prados suffer from, however, they were very clear to me that they have never heard of this problem for 120 series Prados, never !
    My own mechanic reckons it's either the exhaust, or a distorted axle.
    In my head, if it's an axle, I think you'd experience the shudder over the whole rpm range.
    Can't see anything out of place on my exhaust (on the mountings), but I guess there could be a loose baffle inside that is shuddering ????
    I'm at a loss, and it is driving me nuts, next on my list is to chuck in some hi-flow mufflers, not cause I'm chasing anymore horsepower, I just wanna get rid of the this damned horrible shudder, it always comes on at 1000-1200rpm, right in the 60-70 km/h range, when you go up a gradual incline, which is a hell of a lot of streets in Brisbane I can tell ya !
    Any Pradopointers got a clue with this ?????
    Whitey
    Feb 2007
    South Australia
    3,092
    Are the "Dampers" (bolt on weights) tight and in place on the back of the transfer case?
    Mick
  11. #11
    Mar 2009
    Brisbane
    1,064
    Hey Mick,
    I haven't checked, didn't even know there was damping bolts on the transfer case ! Where exactly are they located on the transfer ??
    Thanks, definitely gonna get under there and have a squiz !
  12. #12
    Mar 2009
    Brisbane
    1,064
    Hey again Mick,
    Ok, found a single damper on the back of my transfer case, a black material (seems denser than standard rubber), about 50mm diameter, 30mm thick, bolted into a threaded post which sticks out from the back of the transfer case.
    I notice that there are another 3 similar threaded posts for mounting more dampers, but no dampers on them !
    Is there normally only a single damper ????
    Can someone else get underneath and have a squiz and see how many dampers they have ????
    Thanks !
    Whitey
