Results 1 to 6 of 6
    Fuel Filter Warning Light
    I was travelling down the highway when the fuel filter warning light came on. So I dutifully stopped, checked the fuel filter by pumping a clean flow of fuel, and started up again. Still on. So I disconnected the negative battery terminal, waited 30 seconds and tried again. Still on. Has anyone encountered this problem?
    2007 Prado GXL, Silver, D4D manual
    ARB steel bar, HR tow bar, dual batteries, OME suspension w 50mm lift, BF Goodrich A/Ts, GME 3420, Twine shower and KK Classic CT
    Avid PP Poster! Corigator's Avatar
    Sep 2008
    Sydney
    1,287
    Blog Entries
    1
    Re: Fuel Filter Warning Light
    Hi Hughd,
    I think you are supposed to drain the water from the filter before the light will go out.
    Greg - 08 D4D Prado,
    I should have mentioned that after the first problem I actually removed the filter and checked it. It was clean, so I put it back and drained it again. Still had the warning light on, so I disconnected the battery again. Still the light persists. (Also went through the ritual of the power windows....they work)
    Sep 2008
    Sydney
    1,287
    Blog Entries
    1
    In that case it sounds like the sensor may be stuck.
    Should be a warranty job if its not too late.
    Just to close this one out - the dealer said the filter was clogged and replaced it. They also reset the ECU. It was a new filter (<1000km), but dirty fuel can happen at any time I suppose.
    H
    Jan 2012
    Gold Coast
    61
    I know this an old thread but encountered the same problem in our 2007 Deisel 120 series and managed to reset the warning light by doing the following:
    1. Disconnect top wires/plug on filter housing
    2. Turn Ignition on
    3. Plug top wires/plug back in
    4. Turn Ignition off
    5. Turn Ignition back on and start vehicle
    Hope this helps.
