Handbrake Grief
  • Handbrake Grief
    I know we all get frustrated with the handbrake but the one on my '97 Prado is giving me serious grief!
    I replaced the handbrake shoes which were worn down. When finished there seemed to be too much slack in the handbrake cables. I replaced the cable with a new one thinking the old one may have been stretched but the new one is just the same.
    With all the adjustment taken up at the handbrake, I can just get the LH wheel to lock but nothin reliable. I have checked everything back against the manual including that the shoes and new cable is correct. I have double checked the shoe installation and tried varying levels of adjsutment at the shoes, but there still seems to be too bit too much slack in the cables.
    Has anyone else had a similar problem? Any ideas?
    Bushtreka
    Prado 150D (2017) & Prado 90 V6 3.4L (1997)
    Re: Handbrake Grief
    Hey bushtreka,
    If it helps you to know your not the only one then i"m with ya, haven't got too much help but cause I have new shoes and adjustment on the shoes and cable are as tight as possible you have the little thing you adjust through the backing plate which pushes the actual shoes out and then also a little rubber pad on the back of the backing plate with pulls the slack out of the mechanism then on the actual lever in car for cable right... My handbrake is far less than spectacular but I haven't replaced the cable but which I probably stretched trying to get it to work before I checked it over. I can't see anything more you can do especially if you have replaced the cable... there is a link here which basically outlines the manual from memory but have a look anyways
    http://www.lcool.org/technical/90_series/handbrake.html
      Re: Handbrake Grief
      Have you adjusted the shoes through the hole in the break drum till they binde up, then back them of till the the drum turns free, this should fix the problem.
        Re: Handbrake Grief
        I'm finding that I back them off enough so that they don't rub and I've got too much slack, it's pretty fiddly I've decided mine is near enough
          Re: Handbrake Grief
          Try buying her flowers. By no means a long term fix but it should keep her off your back for at least a day.
          Brett
          2001 GXL.
            Re: Handbrake Grief
            by humphrey on Sun Jun 06, 2010 7:11 am
            Not sure what your drinking but its working for you :roll:
              Re: Handbrake Grief
              :lol: :lol: :lol:
              fortunately I don't have to suffer anymore "handbrake grief" as she's long gone
              Glenn
              Glenn
              2002 GXL 3.4 auto with BFG AT's, Lovell's/Bilstein suspension, ARB steel bullbar, winch, towbar, diff lock, air compressor, GME UHF & AM CB radios.
              [url=http://www.youtube.com/user/gh4wd?feature=mhum][b]Youtube[/b][/url] [url=http://www.panoramio.com/user/2941589][b]Panoramio[/b][/url]
                Re: Handbrake Grief
                I have a similar yet different problem.
                I replaced my shoes thinking this was why my hand-brake was next to useless.
                I found that the adjusters were pretty much all the way in. So I slackened off the cable adjuster at the handle, which was wound up as much as it would go (mechanic's solution). Then I wound out the adjuster at the shoes to the perfect spot on both wheels, and hand-brake was awesome. But within a couple of weeks it has gone useless again. A check at the shoes shows the adjusters have wound themselves back in. Since I have no hole in the backing plate, it is a caliper/disk removal process each time I need to adjust them, which as you can imagine is a PITA :x
                Is there a way of keeping the adjusters set without using lock-tite ??
                cheers
                David
                2013 FJ Cruiser
                265/75r17 Cooper ST Maxx, Rear locker/A-Trac/Crawl
                Losi Comp Crawler for the really rough stuff
                  Re: Handbrake Grief
                  my handbrake replaces her shoes regularly... To fix that issue, Im thinking of replacing the handbrake
                    Re: Handbrake Grief
                    The best writeup I have seen yet is this one.
                    http://www.landcruiserclub.net/forum/vi ... =handbrake
                    KZJ90 1-KZTE GL
                      I find that the blue medium strength lock tite is strong enough for most jobs but will still break free without too much effort, maybe use it sparingly the first time
