Results 1 to 3 of 3
    May 2010
    Sutherland NSW
    2
    Diesel Engine Specs.
    What is the difference between the diesel engines in the Hilux and Prado? Toyota quotes 126Kw and 343Nm for the Hilux and 127Kw and 410Nm for the Prado.
    Addicted PP Member Schaffer's Avatar
    May 2008
    Adelaide, SA
    2,747
    Re: Diesel Engine Specs.
    Different ECU controlling the thing. Toned down in the Hilux as there is significantly less weight behind it than the Prado,
    Mar 2010
    Canberra, ACT
    56
    Quote Originally Posted by Schaffer
    So potentially the ECU are interchangeable, making this a potentially easy performance mod for the Hilux. Anyone out there in BB land that actually works on these things?
    Recipe: Add one ECU from written off Prado and get a major performance boost for your Hilux :^)
    T
