Page 1 of 49 12311 ... LastLast
Results 1 to 12 of 582
    Addicted PP Member glen_ep's Avatar
    Jun 2010
    Western Sydney, NSW
    2,831
    Glen's 90 series Prado getting broken in
    I bought my 2001 Toyota Prado 3.4L in early 2010. It was completely original and had never been used offroad. Since then it's been through 3 stages of mods, blown a front diff, failed several CV shafts and blown 1 motor (ie, supercharged!!!!).
    SUSPENSION/LIFT:
    - 2-3" suspension lift (custom)
    - Custom sway bar disconnects front/rear - UNIQUE!
    - SPC Light Racing UCA's (Upper Control Arms)
    - Total Chaos extreme rear links kit (5x links with heim joints) - UNIQUE!
    - Custom limiting straps (front) - UNIQUE!
    - 1.5" body lift
    DRIVELINE:
    - ARB Air Lockers, front/rear
    - 4.88 diff ratios
    - Custom front diff drop
    - Marks Adaptors speedo correction box
    - Diff breathers, front/rear
    TYRE/WHEELS:
    - 33" 255/85R16 Maxxis Bighorn tyres (also used BFG MT KM2 and Mickey Thompson MTZ)
    - 16x7 steel rims with -13 offset
    - Modified wheel arch flares
    - Custom mud flaps with tie up chains
    ENGINE:
    - Pacemaker extractors
    - Auto Transmission Cooler
    - TRD Supercharger with 7th injector and standard 2.37" pulley (~6 PSI)
    - XEDE computer to manage 7th injector
    - Cooler spark plugs
    - Cooler thermostat
    - Safari Snorkel
    GENERAL:
    - ARB Bull Bar
    - GME TX3340 UHF and antenna
    - NSW engineering certificate
    - Various custom rear storage setups
    - LED Interior Lights
    PROTECTION:
    - Re-enforced rear LCA mounts / rock sliders - UNIQUE!
    - Brown Davis front bash plate, custom modified for diff drop
    BODY LIFT:
    - 1.5" body blocks (8x)
    - Longer body block bolts
    - Steering spacer (inside steering coupling)
    - Extended bump stops for body's cargo area - UNIQUE!
    - Modified radiator brackets
    - Modified bull bar brackets
    - Raised rear fuel tank guard
    - Extended positive battery terminal
    Completely stock as purchased in 2010:
    With 2" lift and 32" tyres:
    With additional 1.5" body lift and 33" tyres:
    BUILD UP INDEX
    Air Filter: Uni Filter
    Battery: custom large tray
    Bearings, front failures after: 10 months, 2 weeks and 3 months
    Brakes: failure and upgrades
    BodyLift: Preparation, Steering spacer, Body blocks, Body bump stops (cargo area) and proof that they are important, Bull bar lift, New radiator (brackets modified but no photos), Before and after photos, main tank, bash plate lift, Rear bumper bracket, Battery terminal relocation, bolt repairs
    CV failures: #2, #3 inner CV joint, #4 snapped shaft and the story behind it, #6 cracked boot
    Diffs: front Air Locker and Air Compressor, switch locations, front diff failure, front diff drop and here, 4.88 ratios and rear Air Locker and: 4.88 ratio impressions
    Engine mount failure and video
    Exhaust: catalytic converter + 2.5" cat back and exhaust tip clearance
    Extractors, 3.4L Pacemaker: Installation, impressions/install tips and Extractor reinstall
    Fuel injector: removal for cleaning and reinstall
    LCA: bushing replacement, anti-seize lubricant, anotherr LCA/bushing failure
    Lighting: LED Interior Lights
    Mud flaps: custom extensions and repairs
    Prop shaft: rear, broken grease nipple
    Protection, Heavy duty bash plate: modified and installed
    Protection: rear LCA mount reinforcement - UNIQUE!
    Protection: repainting surfaces and here
    Rear shelf system: light one for day trips and bed/camping system version 1
    Speedo correction box (Marks 4WD Adapters)
    Startor motor replacement
    Steering rack bushings
    Supercharger: preparation/cleaning, charger install, throttle body, vacuum hoses, 7th injector, charger pulley, vacuum hoses, intake pipe (resonator replacement), charger brackets, Xede computer, Computer tuning software, Dyno, Video result, nose cone replacement
    Suspension: 5mm trim packer in coilovers, 3-4" rear lift, 2-3" front/rear lift and limiting straps, and Total Chaos extreme rear links - UNIQUE!
    Sway Bars: 30mm extended links, failures and finally sway bar disconnects - UNIQUE!
    Tie Rod Ends: replacements
    Transmission: auto cooler and filter change
    Tyres: 265/75R16 vs 255/85R16, MTZ vs BFG KM2, Testing clearances with 255/85R16, new rims, wheel arch / body seam modifications, Maxxis Bighorn 255/85R16, more mudflap mods
    UHF: discreet installation
    UCA: damaged arm and failed UBJ, UCA: Light Racing upper control arm #25460 and here, Flex testing with new arms, Light Racing, worn bushings after 10 months and new SpecRide bushings, alignment for optimal clearance
    FUTURE MODS: (ideas only)
    - Custom auxiliary tank with high clearance
    - Engine/transmission lift for clearance
    - Raise cross members for clearance
    - Full under body protection
    - Raise rear shock mounts, longer shocks
    - Custom rear suspension for more articulation
    - Rock sliders
    - Custom tow bar and protection bar
    VIDEO
    Check out my YouTube Channel for tonnes of videos: http://www.youtube.com/user/glenep
    glen_ep | 3.4L Prado, engineered, 2-3" sus, 1.5" body lift, 33.5" Bighorns (255/85R16), dual lockers, 4.88 diffs, UCAs and some other boring stuff
    * Build up
    * YouTube Channel
    * Mighty 90s Prado Group (on Facebook)
    Aug 2008
    Perth, WA
    2,235
    Re: Glen's 95 series Prado getting broken in
    For a second there Glen I thought you were going to show some pictures of someone breaking into your truck! Lucky surprise though to find this not to be the case!
    NOW FOR SALE!!! - 2004 Silver GXL 3lt 4spd Auto - ARB Bullbar, Safari Snorkel, Redarc Dual Battery System, Cooper ST MAXX, Dark Tint, IPF900XS spots, Raised Bilstein/Kings Suspension/Firestone Airbags, Autosafe Cargo Barrier, Sandgrabbers, Rola Roof Rack Stuff, Insect Screen, Dust/Wind Deflectors, Sheepskin/Black Duck Seatcovers, GME TX3510, ARB underbonnet compressor, Allied Hammer Rims, ARB UVP, AJ Sliders
    Advanced Member two+four's Avatar
    Oct 2008
    Port Kennedy, WA
    663
    Quote Originally Posted by Madkore
    That was my first impression as well, glad I was wrong. Nice Pics
    White 2013 GXL 79 series dual cab, ARB GVM Upgrade, ARB Delux winch bar and scrub bars, GME TX3440 and much more to come
    Jun 2010
    Western Sydney, NSW
    2,831
    LOL, I didn't think of it that way... I just meant, well you know what I meant.
    I probably won't go too far with mods, juist the essentials - but that's what they all say, right?
    * Build up
    * YouTube Channel
    Advanced Member xlr8_87's Avatar
    Sep 2008
    Melbourne, VIC
    587
    Looking good! Bet the Bajas are a bit better than the old Grandtreks?!
    <Rob>
    '93 HZJ80 - DTS Turbo/Intercooler, 35's, Autocraft super flex 3" lift, Part-time 4WD, ARB Winch Bar, TPMS, EGT, DVD, Raslarr Rear Bar, Raslarr Sliders/Scrub Bars
    Jun 2009
    Sydney, NSW
    316
    Glen I also thought....oh crap....here comes the broken window pic's . The elevated pic first off looks like the Prado's on a car transporter !
    Ross
    Aug 2010
    Sunshine Coast, QLD
    22
    hey glen is that the 50th anniversery model i have the same but in the green ,are u happy with the ome suspension? . im thinking of trying the ironman lift or dobinson ????? . have u had any dramas with cv`s at all ?
    Jun 2010
    Western Sydney, NSW
    2,831
    G'day brado,
    Yep, it's the 50th Anniversery model and quite shiney. I thought the 50th's only came in the light silver theme (body + bumpers) so I reckon you should have a closer look at your vehicle. Does yours have velour trims on the doors and rear air conditioning vents on the ceiling?
    I'm definitely happy with the suspension so far. When empty it's great, no complaints at all. With a full load of camping and heavy recovery gear it sags a bit, but there's still enough wheel/arch spacing, and it still handled great. Bare in mind I have larger mud tires, which make a huge difference to the ride quality (sloppy on tarmac corners).
    My only concern with the springs is hearsay - someone else's report of the springs going too soft, too quick, so he recommended the firmer OME springs. I went with ARB's advice, and have had no such problems yet (only ~6 months of ownership).
    No problems with CV's. 40-45mm isn't a big lift so I don't think you'd have problems unless you're pushing those CV angles every weekend with rough treatment.
    *To keep the chat down in build up threads, please reply via PM or in the 90 series sections.*
    * Build up
    * YouTube Channel
    Junior Member g.t's Avatar
    Mar 2010
    Perth
    89
    Quote Originally Posted by glen_ep
    G'day brado,
    Nice looking rig mate
    The 50th ann models come in green also with the colour coded green flares/bumpers. Silver or green was the choice
    Aug 2010
    Sunshine Coast, QLD
    22
    Hey glen
    This is my rig in the green ,just put the 32`s on a few more goodies next year
    Having trouble getting the pictures to come out the same size as yours how did u do it :?: ..when u click on them they come up full screen but dont instantly come up big ????????
  11. #11
    Jun 2010
    Western Sydney, NSW
    2,831
    I finally bought a UHF last week, and installed it last night. I ended up with the GME TX3340 for it's size and mic control - which allows a very discreet and tidy install.
    There's a spot just under the steering which was designed for a speaker, so I've mounted it there with some custom steel brackets:
    The aerial is 4.5db:
    The mic has all the controls and comes with an extension - which still needs a proper install, once I've decided on the location.
    Mic plug / extension location:
    * Build up
    * YouTube Channel
  12. #12
    Jun 2010
    Western Sydney, NSW
    2,831
    Update:
    After braking my front diff on a PP drive I had an ARB locker installed in the front.
    PP drive to Zig Zag:
    viewtopic.php?p=153972#p153972
    Photos from the scene:
    Trip home:
    Diff damage, vehicle rear side spider gear:
    Some damage on the lower gear, which belongs to the driver side wheel. This is clearly where the failure occured (right wheel spinning in the air, then hits ground, and stops = snap).
    Replacement diff with Air locker installed (hose on right):
    Compressor located on driver side of engine bay:
    Switch locations:
    * Build up
    * YouTube Channel
