Mudflap Problem Solved ?
  • Mudflap Problem Solved ?
    Hi there,
    This is my first post, so please be gentle.
    After emails & letters to Toyota re the crappy, do nothing mudfalps on my new Prado 150 GXL & getting absolutely nowhere, I collared the Dealer Principle from my Toyota Dealer.
    He inspected my vehicle & agreed that the mudflaps seemed rather small for their purpose & provided minimal protection at best, particularly as the vehicle was purchased for the specific purpose of towing our caravan.
    He put his staff to work on finding a solution & came up with the following:-
    Mudflaps from a Hi Lux SR5 FRONTS 76625 OK030 & 76626 OK030 REARS 76625 OK130 & 76626 OK130.
    The original mudflaps were left on the vehicle & the new ones fitted as well. The main reasons being that if the rears were removed a hole would be left in the bottom of the bumper bar, the originals would provide additional support for the new ones.
    No holes were drilled in the vehicle.
    If I were doing it, the only thing I would do differently is to use a small "Pop Rivet" in each corner of the original rear mudflap to secure it to the new one, not a screw in the middle.
    I hope this is of help to others.
    Stay safe,
    Tar Trek
    ADMIN (PRADOGXLV6) : FIXED UP PIC LINKS
    Re: Mudflap Problem Solved ?
    They look good.
    i like the method of "masking" your rego
    Cheers, Wayne
      and they even look like they SHOULD be that size... if they are to do any good! Looks like you will avoid the "sandpaper" rear guard look!
      Rick
      2010 D4D GXL auto.: 275/65/17 BFG's /ARB Colour Coded Deluxe Bar / IPF fogs / IPF XD Driving lights / OME Suspension / ARB Towbar / Electric Brake Controller/ Safari Snorkel / "Clark Rubber" Mudflap extensions / GME UHF with town and country antennas / RMW Seat covers & Dash Mat / Full window tint/ ARB~Outback Modular Drawers and Fridge Slider/Cargo Barrier/ ARB Dual Battery Installation with rear outlets/HD Rhino Roof Racks..
        Looks great, any chance of a close up shot of the fitting method?
        150 GXL V6 Auto. BFG AT 275/65/R17, ARB Deluxe Winch Bar, OME 2" Lift, Firestone Airbags, Dual Batteries, GME UHF, Rhino Sportz Crossrails and Platform Rack, ARB Awning, Redarc Brake Controller, Rear Drawer System, Safari Snorkel, New Toyota Mudflaps, Kaymar 'Wheel on Door' Bracket, ARB Under Vehicle Protection, IPF 900XS Spotties, Allied Hammer Wheels. Disclaimer - I am an ARB employee. [B][URL="http://www.pradopoint.com/showthread.php?17348-Sam-s-150-V6"]Buildup Thread[/URL][/B]
          Looks good how much did it run you and have you used it off road as they might tear off?
          Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
            Looks great. good to see all that persistance with the dealer paid off. I will be going to my dealer to get the same done to mine. Great pics to.
            Prado 150 Kakadu, D4D 5-Spd Auto, Silver, Full Window Tint, Hayman-Reese Towbar, Rhino-Bars, GME TX3400 radio, ARB Deluxe Combination Bar, Hella 2000 Driving Lights. PE Brake controller and Complete Campsite XT Camper Trailer
              Tar Trek,
              The bigger mud flaps will be great on road but as someone else pointed out they may be torn off when doing heavy duty off road work . My standard ones are bent back a bit after going through some rough stuff so I reckon the bigger ones would be gone .
              Ross
                Hi there,
                I have not been off road & I agree that they may catch on obstacles, however we use ours for towing our caravan & usually the worst roads are gravel roads in National Parks.
                Unfortunately with the originals we get the double whammy, Prado & caravan damaged by road debris.
                I will definately keep an eye on them to see if they do create any problems, if so I may have to do a rethink.
                I can't quote the actual cost as it was incorporated in an account for other work as well, but what ever it was, I considered it to be quite fair & reasonable.
                The Dealer said some of the mudflaps were not new, however I would never have picked it.
                Tar Trek
                  Hi TT,
                  We have exactly the same problem with towing our van.
                  Great solution and the end result looks very professional.
                  Which dealer in Sydney did you use ??? OK to PM me with info if you prefer.
                  Also, is there a contact name, to save jumping through all the hoops again.
                  Ken and Kristine
                  150 GXL D4D Auto Glacier White
                  Toyota Tow Bar, Anderson Plug, Prodigy P1, Window Tint, Headlight & Bonnet Protectors, Icom UHF, Engel 40lt, Gravel Rush GR150 mudflaps
                  Crusader Mk2 18ft 6in Full Van
                    Hi Cobbo150,
                    I have provided photos & part numbers & that's as far as I am prepared to go.
                    To provide any additional information would damage the relationship I have with my Toyota Dealer & I have absolutely no intention of doing that.
                    I believe my dealer did the work off his own bat at a very reasonable cost to me & for that I'm extremely grateful.
                    Tar Trek.
                      Hi All,
                      Spoke to my dealer re flaps and he advised me that this issue was discussed in a management meeting today as it is now listed nationaly as a often reported item to Toyota. He indicated that Toyota is looking at a fix where those who raise it as a problem at servicing are likely to get a replacement set of flaps. He felt that this is probably a month away from being in place.
                      This is an example of what you get with a 2” lift and a little mud. I wouldn’t like to see to many K’s on gravel with this sort of impact.
                      Casper
                      2010 Graphite D4D GXL, Tracklander tent top roof rack, BFG's, factory tow bar, Black Widow 900 draws with fridge slide, Black Widow Half Barrier with top shelf centre barrier combo, ARB Deluxe Winch Bull Bar (no colour coding), Tabor 9000 winch with Dyneema Rope, Complete Dobinson suspension upgrade and 2'' lift, Dual Battery System, Upgrade wiring to rear fridge plug, ARB On-Board Compressor, Hannibal Classic Tent with Jumbo Fly 1.4M, GME 3440 , HID Lightforce 170's, 2 x 1kg extinguishers.snorkle
                      Still to come, , rear bar, Fridge
                        thanks for posting photos, makes me really think about mudflaps, especially when I get around to fitting springs and shocks.
                        I am getting a window tint done next week and while I am there may consider some clear plastic to protect the panels.
                        Something like this
                        http://www.ducoscratch.com.au/clear_car_bra.asp
                        stepped up the a 200 LC for towing,
                        but had a 2012 and 2010 150 Prado GXL auto diesel in Graphite with Bridgestone D697 A/T. Dobinson C59-300/325 and Bilsteins. Accessories : two baby seats. Sidewinder`s Dual Battery isolator and rear power outlet kit. Pirana Battery tray, Hayman Reese towbar with Toyota wiring kit and Brains`s guard.
                          Good idea maxjj,
                          I was thinking I need a coating down the sides of the vehicle as well,
                          I'll be interested in hearing how you go.
                          Casper
                            Originally posted by casper1956
                            Hi All,
                            Casper
                            could you repost the photos please - they don't seem to be working
                            Dan - Prado 150 GXL - now for sale
                              My apologies Silvo, I moved the photo it in Photobucket hence lost, I've learnt something else today, Photos now back cheers Casper
