Mudflap Problem Solved ?
    Re: Mudflap Problem Solved ?
    Originally posted by casper1956
    My apologies Silvo, I moved the photo it in Photobucket hence lost, I've learnt something else today, Photos now back cheers Casper
    never a problem.
    thanks, i have the same mud pattern.. and that is exactly where the rocks fly.
    dan
    Dan - Prado 150 GXL - now for sale
      I will need Toyota to do the mod and respray the under side.
      This is the result of 1 trip away.
      Prado 150 GXL - V6 Auto, ABR-SIDEWINDER Dual battery System, Tekonsha P3, 50mm Lift kit - King Springs & Bilstein Shocks, Polyair Bags, BFG 275/65R17 Tyres, Milford Cargo Barrier, ERPS Extreme use 10 coupler rust protection, Rhino Rack, Factory Towbar, ABR-SIDEWINDER fridge/freezer, ABR-SIDEWINDER compressor and PSV deflators, Twin Drawer system, Fridge Slide, Twin 23L water tanks, 80W Solar Panel, Hot Water Shower, ARB Awning, Toyota Seat Covers, ARB Winch Bar, Warn XD9000, HID's, Snorkel .
      My website: [url]http://www.sidewinder.com.au/[/url]
        have you spoken with them yet derek? i'd be keen to hear their response.
        i intend on mentioning this in my 10k service
        dan
          dan
          I am about 2k from my next service and will be making a list for them, I will post what happens later.
          The chipping is so bad they will need to replace the rear bumper as I don't think it can be sandpapered back.
          Regards
          Derek
            wow that is bad, no amount of clear will protect that. I wonder if Toyota will say that raising the car by 50mm and fitting slightly larger tyres is outside the design parameters of the oem mudflap, therefore not their problem.
            Still they should know people will do that and provide an alternative.
            Is there any other damage ie behind the front tyres?
            stepped up the a 200 LC for towing,
            but had a 2012 and 2010 150 Prado GXL auto diesel in Graphite with Bridgestone D697 A/T. Dobinson C59-300/325 and Bilsteins. Accessories : two baby seats. Sidewinder`s Dual Battery isolator and rear power outlet kit. Pirana Battery tray, Hayman Reese towbar with Toyota wiring kit and Brains`s guard.
              I have used a ruler and a straight edge and 60% of the damage would occur with standard height.
              No damage to the side steps or front panels, others on the same trip lost sidesteps, especially crossing the Pascoe and at Gunshot.
              Regards
              Derek
                I recently had the rear bumper on my Liberty resprayed, that was $450. Remove, refit and spray. A new bumper was $350, which I didn`t need. Claimed it on Novated lease.
                Guessing here, but removing and refitting the Prado panel would most likely cost more and then add spraying, ~~ around $550-$650 maybe.
                That`s if they can use the same bumper.
                  are those Hilux mudflaps stiff or do they are have a bit of flexibility in them, if they are too stiff I can see them getting ripped off pretty easily
                    Hi there,
                    The HiLux mudflaps are reasonably stiff, not a real problem for me as I only travel on the bitumen or gravel roads in National Parks.
                    Although caution should be exercised when reversing up to gutters.
                    Prime use of vehicle is towing our caravan.
                    Cost of a rear bar for a Prado 150 is $556-50 (inc GST).
                    No change from a Grand, maybe even more to replace & paint.
                    Tar Trek
                      had the car tinted yesterday and asked about a protector film for the rear. They have a .5mm film they typically use as a bonnet protector which they fitted at the rear end for me.
                      The cost was included in the tinting and the whole job came in under $400, so not sure how much that bit was.
                      I appreciate that a .5mm film isn`t going to protect it from the big rocks, but its better than nothing. Also this film can be removed and replaced if its starts to suffer too much damage.
                      Its hardly noticeable and blends in really well. It looks more obvious in the photos than in real life.
                      If I was to go on a big trip that involved a lot of high speed driving on gravel roads I could always stick some gaffa tape over it, especially on the underside.
                      I did that when I rode the motorbike around Australia and it worked really well, it came off easily after 8 weeks on the fairing and left no damage.
                      As a short term fix for anyone, you could just try some gaffa tape, when heading on a trip. Would suggest you try in on an inconspicuous spot first and leave in on for a couple of weeks though.
                      here is a couple of photos
                        Not bad...I was thinking about some that rubber ute tray spray if you could colour match?
                        Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
                          Hi guys
                          Just went to Toyota this arvo in regards to rear bumper damage from rocks. Ours looks similar to Dereks. By an off chance a standard height, standard tyre Prado pulled in right behind me so I showed the service manager the mud spray on their rear bar. He took photos of both cars and said he would have to send it off to Toyota. He was very helpfull in saying rather than just fixing it they need a solution so it doesn't keep happening. I told him about the Hilux mudflaps mentioned in this forum (well done) and he said this is the answers toyota look for to sove these sort of claims. I let him know my car will be in for service in a week so I will see if we have an answer then.
                          Peter
                          [color=#4000FF]2010 GXL, ARB BAR, GOODYEAR MTR'S ON STEEL RIMS, CUSTOM REAR DRAWERS, DUAL BATTERIES, CARGO BARRIER, GME UHF, RHINO ROOF RACK, ROCK SLIDERS, AIRTEC SNORKEL, DUAL DROP FRIDGE SLIDES[/color]
                            went for a drive over the weekend, rear clear protector film worked well at protecting the rear end.
                            But the front is very annoying, they spray hits the bottom curve on the door. I wouldn`t mind so much if its just the sil, but the bottom curve on the door. That is ridiculous.
                            I want bigger mudflaps
                              went in for 10k service and enquired about the mudflap issue and the service manager said he had not recieved any advise from toyota re the issue???? got quote to replace the flaps with hilux ones and its $105/corner mmmmmm
                              2010 Blue Storm GXL Deisel Auto, HR towbar, uniden UHF, 270/65/17 BFG A/T, Delux ARB bullbar (FITTED), IPF Xtreme Spotties, Safari Snorkel (to come) Sungrabba mats (awesome)
                                might have to wait a little longer.. !
