I originally bought my 02/2005 Prado with 42000kms on a clock at back in December 2006. No engine issues to date, however I've replaced the starter motor in 2012, and I'm ready for 3rd clutch. Started towing a 2.4T boat around from Sept 2009 and replaced the original clutch with a extra heavy duty one at 180000kms. I'm currently at 353000kms and looking to either upgrade the vehicle or buy a new clutch and keep it for a while longer. As I mostly fish alone, I'm under my GCM but not by much.
Engine Life of 4.0 V6
My 04 just had its 380,000km birthday, whilst crossing the Simpson Desert from Home to Birdsville then over to Mt Dare then to Alice Springs via the Finke04' 120 PRADO GXL 4ltr Petrol V6 4mm bushskinz steel bashplate 8Tonne recovery points Ironman 4x4 Snorkel 2” lift and other bits of fruit, ready for the next adventure
MIne has 283K on the clock, '04 GXL 5 speed manual. I don't know how many owners, but I will be the last. Engine is outlasting other things on the Prado...[FONT=Century Gothic][B][SIZE=4][URL="http://www.pradopoint.com.au/showthread.php?36057-Ryback-s-Flinders-Red-120"][COLOR="#B22222"]'04 120 Petrol Flinders Red GXL[/URL][/COLOR][/B][/FONT][/SIZE]
Just hit 450k with mine. Starter motor got replaced about 5k ago and the front bearing / crankshaft balancer seal is gone but still a while to go before the oil leak gets too bad. Other than that all pretty good so far. I bought it 10 years ago with 145k on the clock. Friends said I was mad buying such a high mileage car but I sure can't complain.[color=#BF4000]2003 V6, Auto, GXL, Factory Bullbar, Rhino Roofbars, Bosch and Hella spotties, Cooper AT3, Bilstein shocks, Ironman awning, GME UHF, MaxTrax.[/color]
[url]www.kymarphotography.com.au[/url]
Originally posted by mkh View PostJust hit 450k with mine. Starter motor got replaced about 5k ago and the front bearing / crankshaft balancer seal is gone but still a while to go before the oil leak gets too bad. Other than that all pretty good so far. I bought it 10 years ago with 145k on the clock. Friends said I was mad buying such a high mileage car but I sure can't complain.
I own a 2003 GXL. I’ve taken it all around the country including Kakadu National Park about a 1000kms out from Darwin.
just clocked over 350000km. Engine going strong (has a small oil leak on left side of engine housing ?timing over location - mechanic says it’s not a problem). running so smoothly it’s crazy, still feels and drives like the day we got it back in WA 17 years ago.
Here are the major issues I’ve had to fix so far;
270000 km - new starter motor (fixed for $350)
320000 km - radiator leak (at a corner weld join it looks like) - second hand radiator bought for $88 + $220 labour/fluids
350000 km - major transmission leak (blown seal with broken torque converter) replaced the entire A340F + transfer case with a second hand transmission for $500 + about $1000 of labour + new ATF fluids including flushing of all lines/transmission cooler lines.
17 years on and a total of $2500 of replacement parts.
Am very happy with both the car and the ready availability of cheap spare parts from wreckers to keep her going!
Originally posted by Atherton View PostPlenty of falcon taxis getting around with that sort of mileage (700K). It all depends on how the car is driven and what maintenance is done on it.2005 120 series V6 Grande, 2 inch susp lift (King/EFS combo), 32 inch MT’s, Safari Snorkel, rear diff lock, breathers, Light Force spotlights, UHF, dual batteries.
Heat cycles play a huge role in engine longevity. Those falcon taxi's (or any vehicle doing a similar job) will likely have a very long lifespan with minimal engine problems as they're constantly running and typically serviced regularly- Contrast this to an engine that gets started up for a 15 minute trip 3-4 times a day to drop the kids off or do shopping that is getting turned off shortly after warming up to operating temperature.
Originally posted by Cazz View PostHi I was researching when I came across this thread. I have a 2004 Prado with 430000 on the clock and hasn’t missed a beat until recently. Everything is great except when I tow a camer trailer. I’ve had to top her up with coolant twice over two weeks. Never have to normally.
- 1 like
