Big Flex - Here is what you need
    Re: Big Flex - Here is what you need
    [quote=double_d69]
    Originally posted by "Auto-Craft":2op7kozp
    You might want to try some flat bar of at least 5mm for the coil retainer bracket.
    Thanks for the advice. Do you think 5mm is necessary of the coil retainer? [/quote:2op7kozp]
    No, I think AT LEAST 5 mm as a minimum, is.
      Yeah they are great shockies, I have them in the rear too but unfortunately they don't have the same travel as your toughdogs.
        Originally posted by Wade76
        Originally posted by ookami
        Nice Work, out of interest why didn't you go the Icon adjustable UCA? Couldn't justify the extra US$500 or were you worried about the uni ball longevity, from what I've read and been told they are meant to be best for freeing up down travel?
        I went abit silly with the credit card and got the icon uca's and remote resi's. This has given me a full droop of 890mm so only an extra 10mm over double_d69's setup.
        So what is stopping more travel are the Arms binding on anything or is the shock bottoming out? Or any of the other bits brake lines and stuff limiting it? I'm tossing up whether to order the Ext Travel remote res ones or just go with the standard travel non remote res ones and save $250.
        2014 D4D 150 Prado soccer mum mobile
          Def go extended travel
          [b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
            ookami yes it's my uca's that are binding but I think I should be able to gain some more travel. My intial measurements were taken before I raised the front to a ride height of 820mm, my full droop measurements now are 895mm on the drivers side and 887mm on the passengers side. It's looks like the guys who did my wheel alignment were abit dodgy and mainly used the lca to adjust the passengers side and the uca on the drivers side, since the uca has been adjusted out more on the drivers side it's giving me more travel before binding. I have my car booked in on monday with a suspension shop to get the uca's set up properly to gain max droop.
              Any chance of pics of your car side / front etc on, on flat ground, not flexing?
              More to come!
                i know its a necro thread but just wanted to get some feedback about the SPC LightRacing UCA's. How long have they lasted, any issues & etc.
                just looking to add a set to my 120 and looking at the Superior Engineering, SuperPro and SPC sets.
