Page 2 of 11 FirstFirst 1234 ... LastLast
Results 13 to 24 of 132
  1. #13
    Jan 2009
    Wallalong, NSW
    34
    Re: Steinbauer Performance Chip
    Hi,
    Has any one run a Steinbauer chip on the 150 with stock exhaust, or all most running a high flow job?
    2010 VX
  2. #14
    Member Giles's Avatar
    Jun 2010
    Sydney, NSW
    115
    Quote Originally Posted by Eugene
    Hi,
    Hey Eugene,
    Our Kakadu has the Steinbauer and standard exhaust at the moment.
    Our Sterling Humex exhaust should be availible soon.
  3. #15
    Inactive
    May 2008
    Geelong Vic
    270
    On the Prado, we have just been replacing the muffler, at $270, and finding it is within 3-5 kw at the wheels, of fitting the whole aftermarket exhaust, with no extra in car noise.
  4. #16
    Mar 2010
    Sydney, NSW
    910
    Quote Originally Posted by Auto-Craft
    I assume you mean replacing the muffler only is within a few KW's of replacing the entire exhaust system. One quote in Sydney was for a full replacement at $900-, to which the missus said, *#&! off.
    Does the muffler only replacement give much power increase? I assume that the muffler is full of baffles, which is causing the air flow problem and the rest of the system is O.K.
    Any of these mufflers in Sydney, or will any fit?
    Yowie.
  5. #17
    Mar 2010
    Sydney, NSW
    910
    Hey,
    We are in Sydney. Feel free to contact us and we can point you the right way.
    The Steinbauer can be un-plugged and re-fitted if your concerned about what Toyota think.
    We do alot of dealer work and none of the accessories come under scrutiny.
    Also Stenibauer are backed by Diesel Care Australia so they have a great understanding of the product. You will NOT
    have a problem with warranty.Good example is we ordered our 150 Kakadu from our dealer and had fitted the whole assortment of ARB gear including
    OME suspension and the Steinbauer...Once we were finished we sent it back to be PD'd. We have also sent our 200 back to Toyota to check as we were helping them with
    the Oil consumption test and neither the Steinbauer or Exhaust has ever been questioned.
    Giles [/quote]
    Giles,
    Is there anything you can do to boost a petrol 150 (not with a turbo).
    Yowie.
  6. #18
    Inactive
    May 2008
    Geelong Vic
    270
    I wont go plug us on here, but perhaps those who have purchased a Stienbauer from us and got thier P.P discount [vendors section doesnt allow members access to these without contacting us any more] could put out some details 8)
    By changing the muffler we see aprox a 7% increase in low down throttle response, and we can then tune the Steinbauer to suit the heat escaping out the more free flowing muffler and better low down response.
    The steinbauer tech performance sheets we find to be slightly under rated.
    You can do petrol as well, I will be doing a build up on the FJ I have on order with the 200kw dual VVTI V6, which includes liquid injection LPG, a tuning device for the computer, extractors and exhaust, I have the 415 HP Safari snorkel for it already, air cleaner, etc.
    So far 15% more power than petrol is available just from the liquid injection gas.
    I expect the other mods to add about the same.
  7. #19
    Avid PP Poster! krypto's Avatar
    Oct 2010
    Perth
    1,466
    Can someone suggest a place in Perth to get these fitted?
    Also does this have any effect on the 1500rpm drone?
    Steve
  8. #20
    Mar 2008
    Perth, WA
    19
    Quote Originally Posted by krypto
    Fremantle fuel injection They have installed mine and also tuned it .
    Great to deal with as well
  9. #21
    Quote Originally Posted by Auto-Craft View Post
    We have done afew of these on the 150, and they improve down low throttle responsivness, and make the vehicle nicer to drive.
    The Steinbauer is the pick of them with inbuilt safety feature.
    We also find the performance charts are underated generally for the improvement, from them.
    Can I beg to differ??
  10. #22
    Quote Originally Posted by Giles View Post
    Dead on. Its the only chip we will install.Our whole fleet is running Steinbauers The 200,Hilux,BT50 and as of the other week the 150.
    We also run the Sterling Humex exhaust systems on all bar the 150 as we are waiting for it to be made.
    You will not look back from the Steinbauer FANTASTIC.
    Giles
    Giles you should try ours as a comparision. You may be a SB agent but there are a lot of people that want / need more power than what is offered by SB. That's where we could fill the gap. Just one comparo between the two chips will be all it takes.
    Give us a go ... the money back guarantee is your protection that we have a great product.
  11. #23
    Addicted PP Member Schaffer's Avatar
    May 2008
    Adelaide, SA
    2,747
    Hey Robert, do you have a chip to suit the 1KZ 120 series TD yet? I've spoken to you guys numerious times and have always been pushed towards petrol injection which is not what I'm after. At one stage there was a stronmg suggestion that a chip was being engineered. I have friends who have purchased a Chip It chip for various vehicles (eg 200 series, Hino truckes and others) and they rave about the performance benifits for the cost of the chip. Would be rather dissapointed if no chip ever eventuates (similar to what I believe happened for the 100 series)
  12. #24
    Out of control poster! MidLifeCrisis's Avatar
    Sep 2010
    Adelaide SA
    5,623
    Blog Entries
    1
    Quote Originally Posted by Chip It View Post
    Rob, I have the CHIPIt on my list of "to-dos". It is a short list with only the 3 inch exhaust (Manta) ranking ahead which goes on in as soon as its shipped from WA. Greg at Sprint Auto SA will be doing the install of the chip.
    I attended your premises in WA up near Clarkson ?, (well at the end of the freeway just south of Exmouth lol) while in WA recently and was impressed so you have my order. The other two factors that have influenced my decision are you taking the time to address concerns on this forum and the discount you are about to offer me .
    Happy if you want to use my rig to run some graphs, post up some before and after results etc, especially on these forums.
    Rob
    Bitumen: A blatant waste of taxpayers money!
    My rig buildup Mundaring Power Lines Jan 01 You Tube Video Morgan Quarry
