Exactly right, it is used to power a relay mounted in the van. The relay switches the Van bat power to the fridge. It seems a lot of vannies run the 12V fridge power through the trailer plug (pin 2 which is the rev wire), to my way of thinking trailer plugs are not designed to run large current. It obviously works but to me it is high risk.
Useful Wire Colors and locations
Originally posted by rexie04 View PostAnyone able to advise what the wire colours are for the reversing camera and what plug they come thet go to behind the player?
MikeMy Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
Anyone know of a pick up for IGN that is only on after the car starts? Preferably down the back of the car as I will be running it to a relay for a 3 way fridge.
I did go looking for the green wire near the 240V outlet as outlined in the post above, but it is not there in a GX.
Cheers.Last edited by cbm8880; 27-04-2012, 04:08 PM.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
2008 Jayco Dove Outback - "Davo"
Yeah I have thanks. I'll use that and send it through the reverse pin in the trailer wiring I think.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
"Green Wire, Drivers side of the Engine Bay above the brake booster going to the wiper motors"
How do I tap into this wire? Any suggested methods?2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
The easiest way. Skin it, wrap your new wire around it, solder then wrap with electrical tape. For added protection smear a bit of silicon/silasitic over it.
That's how I do it..Blue Storm 150 D4D GXL, Toyota Tow Bar, Cheepo floor mats, Tough Dog Springs & Shocks, Colour Coded TJM T13 steel bar, KingOne winch with rope, GME 3440 80 channel uhf. Not allowed to make hole for snorkel - yet..
Actually, the easiest way is to buy a wire tap connector. Though, I also do as footoo has done when I don't have a wiretap connector handy.
http://www.supercheapauto.co.nz/onli...46#Description
LFaR.[size=1][color=#770000]29Feb12:[/color][color=#777700]12GXLTD Auto, ARB Deluxe Winch bar, WARN 9.5xp Winch, IPF 900XS, Tow, Safari snorkel, Front + Rear Recovery points, ARB OME NC Sports, ATZ-4Rib[/color][color=grey], Silver[/color]. [color=orange][b]MaxTrax[/b][/color], [color=maroon]ScanGuage II[/color], [color=blue]ARB CKMA12[/color], [color=deeppink]UHF: GME TX3440 AE4018K1 UNH047SX[/color], [color=darkgreen]Bushranger Air Jack[/color], [color=green]Staun + ARB Deflators[/color], [color=brown]WindCheetah Roof Rack[/color], [color=green]Foxwing[/color], [color=red]Super Charge MRV70, Redarc BCDC1220[/color], [color=darkblue]ARB 60L fridge[/color], [color=blue]MSA Fridge Dropdown slide[/color], [color=darkyellow]DRIFTA Drawers[/color], [color=gold]TJM Bash Plates[/color], [color=brown]TG150[/color].[/size]
IGN wire in rear of vehicle
Ok, so I have found an ignition wire (similar to the front wiper motor) in the rear. I found it from the rear wiper motor :-)
All the wires going through the flexible conduit into the rear door are black, however up near the motor, then pass through a connector and then regain their colours. I found that the purple wire was live with IGN on only, so i then used the wire tap (post above) and fed a wire back down through the flexible conduit into the car.
Im pretty sure you could trace this wire down to the rear quarter panel if you wanted to, but they are all black there, so identifying it may take two people (instead of running up to the front of the vehicle to turn on and off the ignition.
I then went on to wire this into the 'reverse' pin of the trailer wiring harness, and am using it to trigger a relay to run the 3-way fridge (on 6 b&s).2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
Originally posted by cbm8880 View PostOk, so I have found an ignition wire (similar to the front wiper motor) in the rear. I found it from the rear wiper motor :-)
I think the wire you actually want at this connector is the Sky Blue wire which is the battery supply to the rear wiper motor.
Both the above circuits are protected by individual 15A fuses (WSH RR and WIP RR) supplied from the battery (via a 30 fuse WIP WSH RR) through a relay that only operates when IGN is active.
Fuses and relays are at left hand end area of engine fuse block looking from front of vehicle.
If I am wrong somebody will correct me I hope.
Good luck
Prone2018 Prado 150 VX Auto
Thanks Prone, I'll check it out and see what it does. Do you have a wiring diagram that you are referring to?2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
Originally posted by Prone View PostPutting a load on it like a relay may cause a constant current to flow in the washer motor leading to heating
Also, the wiper motor will only run if it is grounded through the motor right? Having tapped the wire 'upstream' (ie live) of the wiper motor it shouldn't run should it?
Sorry I'm a bit of a basic 12v hack.Last edited by cbm8880; 05-05-2012, 07:36 PM.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
