Originally posted by cbm8880
View Post
Tapping "upstream" would be OK. However the purple wire is downstream of the washer motor. All the switching functions for the rear washer and wiper are done by switching an earth or ground at the wiper switch. The battery supply to the washer motor is a blue wire if you ever find the motor, I'm not sure where it is located. Maybe in engine bay?
The "Sky Blue" wire is the fused battery supply to the wiper motor. Will be at 12V while IGN on.
The purple wire with the ign on will sit at 12V. Operating the rear washers should bring the voltage on this wire down to almost 0V. This would be a good way to check if I am right or wrong.
Saw the wiring diagram some time ago and scribbled a few notes. I have not checked this on my own vehicle. I was looking for 12V supply for similar use to yours.
I may be wrong in my recollection, if so I am sorry.
Prone
