Page 1 of 2 12 LastLast
Results 1 to 12 of 14
    Confused much! Diesel VS Petrol/Gas
    The more time I spend 'researching' on here, the more confused I get...............
    Hubby's mates at work say 'diesel' mate - it's the only way.
    I read on here both sides.............
    In your opinion - diesel or petrol/gas and why?
    Engine wear and tear.....................$$$$$ anything else???????????????????
    We mainly do highway, local driving, occassional beach...........and have never done the real '4wd' stuff - not to say we wouldn't - just haven't yet. (Probably do approx. 250/300 ks a week on average)
    Jan 2008
    Toowoomba, QLD
    328
    Re: Confused much! Diesel VS Petrol/Gas
    There are a whole lot of reasons why we went petrol rather than diesel and would do so again. We are also on LPG which has its benefits but I don't think I'll bother with it next vehicle - unless its already installed.
    Before we made the purchase I did up a spreadsheet on which I did a cost/benefit analysis for diesel v petrol. On balance, the cost of ownership came out pretty close but a bit in favour of the petrol. This is because the increased cost of servicing the diesel exceeded the increased cost of fuel consumption in the petrol. Its just that you notice the small added cost at the bowser each week while the inreased service costs of the diesel only hit every few months. This is the mistake a lot of people make, they look at just the cost of fuel without taking into consideration all the other costs of owning a diesel - not to mention that a petrol is quieter and much smoother and more powerful drive. I no longer have the speadsheet, but FYI, here are some of the factors we considered.
    Benefits of Diesel over Petrol:
    • less fuel consumption; a bit more torque in extreme off-road conditions and/or towing; expectation of long engine life; better resale value
    Benefits of Petrol over Diesel:
    • MUCH MUCH more get up and go - better around town, better for overtaking on the highway. Lower servicing costs: 120 series change oil every 10,000ks, diesel 5,000ks. NO timing belt to change on the 120 series petrol - petrol has a timing CHAIN diesel has a Belt. Diesel costs more to buy than petrol. More bang for your buck, you can buy a later model petrol (go for the 120 series if you possibly can) with lower ks. The better resale for a diesel is a myth. Sure you get more for a diesel when you sell, but you have to pay more for it in the first place - the resale price will be lower for the petrol but the buy/sell difference should be about the same. Engine life is probably a myth too - the petrol engine is renowned for its exceedingly long life so the this is not imho an issue.
    On balance, with the petrol you get to drive a later model car with lower ks. You get a much better day to day drive. Your average running costs are about the same as the diesel.
    Hope this is of some use.
    Bear
    2005 4L V6 5sp Auto GXL. Not much gear!
    Mar 2009
    Melbourne, VIC
    686
    Quote Originally Posted by Bear
    On what basis do you make that statement ? I find here in Melbourne that it is often a fair bit cheaper per litre than petrol, but depends where you are in the petrol discount cycle. ( diesel is more stable in price so doesn't matter so much when you fill ).
    And I guess you have driven a D4-D diesel to compare with the petrol ?
    Otherwise your arguments are pretty sound.
    But i still love my diesel. - you maybe forgot to mention in the diesel "pro" list : better range especially if you do long distance touring, and better availability of fuel in remote areas. If it's only going to be a "town" car there's probably a good argument for a petrol.
    I may consider a petrol with LPG again on my next vehicle - it all depends on what fuel prices do.
    Maybe none of us will be able to afford to run any fossil fuelled vehicles in the next 5-10 years.
    Cheers, Wayne
    Out of control poster! AJ120's Avatar
    Nov 2009
    Going where no Prado has gone before.
    7,355
    It really depends on what you are going to do with your Prado, If you are going to be travelling around in mostly built up areas with relatively short stops between fuel points then either would be fine. If you have plans on doing a lot of remote area long distance outback travel, you aren't going to find many places to buy gas in the outback so you will have a thirsty vehicle with a relativly small Petrol tank = not enough touring range.
    Everyones situation is different, in my own circumstances diesel is the only option i would consider, and financially i believe that i am miles in front with the diesel. your circumstances are probably different.
    Bear mentioned that diesels are dearer to buy, which may be true most of the time, however when i bought my first Prado in 2005 Toyota had a "special" and both Petrol and Diesel where $49,999 drive away, so make sure you double check prices before taking the plunge and dont just expect diesels to have a higher purchase price (although they most likely will)
    So Long and Thanks for all the Fish!
    MY PRADO AND DIY CAMPER TRAILER
    I spent many hours researching the pros and cons of diesel vs petrol while waiting for a Prado to come up for sale. In the end I found a petrol at the right price and am very happy. If it had been a diesel I still would have bought it and I'm positive I would still be happy. So I think either one you cant go wrong, if buying secondhand look at both until you find the right one whether its petrol or diesel.
    2004 GXL V6 and loving it.
    Jan 2008
    Toowoomba, QLD
    328
    Quote Originally Posted by ozwapet2
    At the time we were making the purchase decision, diesel was (by my recollection) about 5% dearer than unleaded. My research was limited to Toowoomba prices. We just returned from a trip to Tassie. I noticed that in most areas unleaded is a bit cheaper than diesel, but at times the price is about the same. The price gap may have closed a bit too. But the real cost factors were, in my calculations, the service costs and the up-front purchase price.
    Probably a whole lot of other "pros" for diesel too - I guess you would have to own one to know.
    If one was planning extensive long distance and/or remote trips (or a lot of towing), I'd agree - go diesel. Petrol works well for 85% town and highway, 15% remote and/or off-road.
    Bear
    Thanks!
    The look continues...........but probably not so narrow now..............
    Jun 2010
    Perth
    796
    If you are talking earlier 120 series with the 1kz ( not the d4d the toffs drive 8) ) then the gap in fuel costs is not huge between the petrol and diesel. If you look at the fuelly results in some of the members sig blocks it seems an average of around the 12.5 for the diesel and 14.5 to 15 for the petrol.
    If you are happy with the relaxed pace of the diesel get one, if you want the grunt of that sweet V6 then hang the extra few bucks in fuel and get the petrol.
    Whichever you go with, just do it!
    Prados are great!
    Feb 2010
    Kawerau, Bay of Plenty, Whakatane, NZ.
    273
    Hi Fellas. Here is one arguement not often used for running a diesel. It's a lot bloody safer in the event of a prang. With petrol, one flash and yer ash. Diesel takes a lot of getting burning. If you are going bush, diesel is less likely to evaporate due to the viscosity and hence no explosive fumes. Your prado will go further on a tank of diesel, it will run cooler when working hard and if (god forbid) you need to use fuel to light a fire, diesel won't blow your eyebrows off. BTW did I say I prefer diesels? Cheers, Derb.
    2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
    Member hisham saeed's Avatar
    Aug 2010
    Cairo , Egypt
    189
    Blog Entries
    1
    although i haven't tried Diesel before, but from what i read about the D4D, i would give it a go.
    actualy i wouldn't care as long it is a PRADO , the main factor would br the condition of the car and you should ask yourself do you prefer slowly but sure or great power? i choose power, especialy here in Egypt most of the prados are diesel 4cly. I remeber when first got my prado i was on the highway and when i passed a Dodge Ram with V8 Hemi engine 5.7L , the look on the driver face :shock: he kept following me and looking what is under that bonnet.
    one more thing why not test drive either car before purchasing ? is it doable in Australia ?
    enjoy your hunt.
    hisham
    2006 VX ,5 Auto , currently Scan gauge II , Bonnet Guard ,wind deflectors,head lamp cover, dust deflector,insect net , Engel fridge,IPF fat boy,Hella FF300 lights,Toyota HD bars,BF 265/70 R17 A/T, Hella TPMS, K&N,OME 2",DBA , AirLift 1000 & Wirless Air control , ARB Comp,Safari Snorkel.
    http://www.fuelly.com/smallsig-metric/52690.png
  11. #11
    Avid PP Poster! kav's Avatar
    Jul 2010
    Caringbah, NSW now home of the almost sober fool
    1,525
    Blog Entries
    3
    don't buy anything with gas on it ,you'll regret it . ooh that'll get some comments . :P lets clarify that .unless its fitted at the factory as a full gas only system and comes with a warranty. good luck finding someone to fix it in the boonies or getting gas in the first place .
  12. #12
    Avid PP Poster! KAKADAZ's Avatar
    Mar 2010
    Perth, WA
    1,200
    I weighed all the pros and cons and went the petrol I couldn't be happier. Read the latest 4WD action magazine regarding small cube diesel engines trying to move heavier vehicles. The biggest problem with the new CRD engines is the 3000psi pump pressures require absolute 100% perfect fuel if you get one bad or even just not perfect fuel it can result in very expensive pump failures. An article in the mag talks about a family traveling with seven other families in a 2010 patrol diesel that spat a fuel pump and had to be towed (by a Toyota of corse) 190ks through the Simpson desert only to result in a $10000 bill not covered by warranty. The top 4 motors experiencing CRD issues were
    1- Toyota D4D
    2- Nissan 3L
    3- Nissan 2.5L (pathfinder)
    4- Toyota land cruiser V8
    Over this weekend just gone I passed my mates 2010 3L patrol going up steep sand dunes because he had simply run out of power and couldn't get his to rev hard enough (it literally kept dying in the arse) whilst my V6 was absolutely tearing up the dunes with no low range ever needed.
    Weigh up the price of the car the price extra for diesel fuel and the extra servicing and it simply didn't make financial sense and I would have been an underpowered tractor (not what I wanted for a 90k car). If you do a lot of outback touring you better hope every stop in the bush has perfect diesel.
    Mine also returned over eight days of beach work and pulling my 1400kg Windsor rapid a combined total of 17L/100ks .....I can live with that.
    http://www.pradopoint.com/showthread...daz%27s+kakadu
