Toyota WS Fluid Servicing and Longevity
So to do a fluid change yourself, it's not required to use a piece of wire across no 4 & 13 terminals as stated in workshop manuals to put the Auto into service mode??
Steve JD4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
Originally posted by CaLLaN 52 View PostSo to do a fluid change yourself, it's not required to use a piece of wire across no 4 & 13 terminals as stated in workshop manuals to put the Auto into service mode??
Steve J
Ok ####, let me know when you are available, can you get the ws
'fluid or do u want me to see if I can get 12 litres??
SteveD4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
Thanks Andrew,
Will try that method, seems simple enough
Originally posted by CaLLaN 52 View PostOk ####, let me know when you are available, can you get the ws
Steve
Cobaw the week after, so maybe the weekend after Cobaw, will talk to you there about it
Originally posted by AJ120 View PostI changed the trans oil Today, those instructions certainly make it an easy job. Just be aware that on the D4D the inlet pipe into the Radiator cooler is the lower hose, so I removed the top hose and used a scrap piece of hose from the top outlet on the radiator into my collection jug. I also used a tom thumb oil pump for the refill process.
The service guy at Toyota assured me I didn't need to do the change when I asked about oil, but he sold me some none the less. I showed him a sample of what came out after the job was done and he was a bit shocked, it looked more like used engine oil than Transmission oil!
The transmission has significantly improved after the change, sharper and smoother I reckon.
I don't think I will wait 80 thou until it gets its next change.
Originally posted by gxl_d4d View PostOnce an oil cooler is fitted, the fluid stay pink a lot longer. I've done 40 000km since the last flush and installation of a cooler. The fluid is still pink. I've been checking it every 10 000km for colour. I was planning to flush it every 40 000km initially. I think I'll run it a another 20 000km and assess the situation.
You don't have to buy Toyota ws.
There is a Penrite one in 20ltr.Last edited by Anth120playdo; 06-05-2014, 07:05 PM.
Had mine done at 90k and was told that they use a flushing machine to do basically what you have done above, except they can run it continuously I suppose. Anyway, asked for a sample and it looked pretty much like coke. I'm told they check the oil condition at each service, but the state of mine would suggest otherwise. Not sure about the WS oil either as I was told that the earlier 150's (including mine) did not have it from new, in any case I am yet to be convinced that any oil will last a lifetime, even if the oil was able to remain stable, it's secondary job is to remove contaminants and suspend them until picked up by the filter, but the filter will only pull bits out down to a certain size, anything smaller stays in suspension and builds up in the various nooks and crannies of your tranny.Kev,
Originally posted by jika View PostHi Kev, did toyota do your flush or a specialist auto shop?, can I ask how much it cost you
Tow a van at times, and the auto fluid was slightly darker, but not too bad. Standard response from service dept. is that the fluid will last for the life of the vehicle and won't need changing. Do not agree with that, and told them so.
Can anyone point me in the right direction in relation to the oil for the 4 speed auto in a 2003 Grande V6?
I have had a look at the Penrite site (based on ####'s information above) and it comes up with two different types (a Full Synthetic and a Semi Synthetic) - info in picture.
Also, it has a note (259) which states the following: Models from August 2003 (refill plug marked 'WS'), use ATF FS MULTI VEHICLE FULL SYNTHETIC AUTO TRANS FLUID.
Still not sure if the 4spd uses the full or semi synthetic and really don't want to make a costly mistake.
Thanks in advance guysPitbull - 2003 4.0L V6 Prado Grande.
Accessories - ARB Deluxe Non Winch Bar, LED Indicators / Parkers, 55w 6000W HID Headlights, 100W 7" HID Spotlights, AMTS Heavy Duty Radiator plate, Cooper ST Maxx Tyres..................thinking about the next big spend!
So all done - ended up using a Nulon full synthetic (Product code ATF4).
Being a 4 speed (which has a dipstick) and a V6 (has a transmission cooler) I just disconnected the top cooler line that goes through the radiator support on the passenger side, extended the line to the floor using clear hose as previously mentioned so I could monitor the colour of the fluid and switched the car on to pump fluid into a canister to measure what was drained.
I then topped up through the dipstick tube, 2 litres at a time out/in.
After 12 litres the fluid had changed colour considerably - went from looking like used motor oil to slightly discoloured when compared to the fresh stuff.
Have done about 1500 kays since and the shift isn't noticeably different but the car seems to need less accelerator to hold speed at the upper end (80-110 kph) and the transition from Drive to Neutral and Reverse seems to have sharpened up (there isn't the lag in the gearbox picking up the reverse gear that there was previously).
All in all, pretty painless exercise and well worth the money spent in my view - I will definitely do again every couple of years maximum.
Thanks for the advice guys.Pitbull - 2003 4.0L V6 Prado Grande.
