Did you take any pics?
Front Guard mount spot welds failing
Originally posted by D4D View PostDid you take any pics?
Finally solved my rattle from the front end !
CheersPrado VX Diesel 2007 Silver
Lots of add-ons...
[url=http://autos.groups.yahoo.com/group/aussieswag/join][img]http://autos.groups.yahoo.com/group/aussieswag/[/img][/url]
[i]Click to join aussieswag[/i]
Hi Slamminsammy, my 2004 did the same with those brackets after I did the Canning. Clearly the spotweld is either not enough or poorly executed. Prado's are good but they aint perfect. My fix was same as yours
Borgy, it is possible your bracket is the same one only photo taken from totally different angle. You may have to remove a headlight to check
Cheers.......WayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
i guess i know what im doing tomorrow afternoon.2012 Suzuki jimny 50mm lift, 215/75/15 hankook muddies, 30 inch dual row light bar, gme UHF, arb compressor, rola roof rack, ironman awning, projecta dual battery system with yellow top optima, evakool fridge freezer and arb air locker this month!
Yep, very common issue especially if you've done any corrugationsHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
