ARB 150 Series Bullbar Fitting Instructions
  • ARB 150 Series Bullbar Fitting Instructions
    3221450 Deluxe bull bar (To suit SX, GX and GXL vehicle models)
    3421470 Deluxe combination bar (To suit ZR, VX and Kakadu vehicle models, and is equally suited to winch and non winch applications)
    3421450 Deluxe winch bar (To suit SX, GX and GXL vehicle models)
    3921460 Sahara bar (To suit ZR, VX and Kakadu vehicle models and is equally suited to winch and non winch applications)
    3921450 Sahara bar (To suit SX, GX and GXL vehicle models and is equally suited to winch and non winch applications)
    [COLOR=#000080]Nick[/COLOR]
    Re: ARB 150 Series Bullbar Fitting Instructions
    Does anyone know if the Deluxe Bar has the spottie mounting holes already drilled or will they need to be done. I am having one fitted to my GXL next Friday and need to know. I am not keen on drilling it once it is on the car.
    [b]2013 GXL LC200 TTV8[/b]
    TJM Alloy Bullbar
    Towing a Jayco Expanda 17.56-2OB
      They should be standard and would not require drilling. Well at least that's how it was on my Deluxe Winch bar for my 120 and the same way I've seen them for many other peoples vehicles (Prados, Landcruisers, Pajeros, Discos, Patrols, etc...)
        Does anyone have arb install instructions for the 150. The links above don't seem to work anymore?
          I'm too after install instructions
            I fitted an ARB Bull bar to my Prado last weekend, pretty straight forward if you have all the bits. There is a 4 part youtube video that shows you how to do it, just google "fitting arb bullbar Prado 150" (its not an ARB bar but the way it is fitted is almost the same).
            I have the cutting template if anyone needs it.
            Phil
            2013 GXL DIESEL AUTO, ARB BULLBAR, IRONMAN SUSPENSION, TOYO OPEN COUNTRY A/T2, JAYCO DISCOVERY OUTBACK
              Phil
              what did you use to hold it into position while it was bolted on?
                My wife.
                I bought the bar off Ebay for $200 and then got it painted, pretty happy with the result.
                stephcott
                  can i get the fitting instructions and template from you?
                  Phil
                  I bought an ARB bar from gumtree for my 2010 Prado GXL and could use the template of you have it please
                    whats your email address
                      Just PM'd you. Cheers. MG.
                        Not sure if its still possible but does anyone has a cutting template
                        cheers in advance Luke
