Guys, just reading a thread on Lcool about splitting/ cracks in the sidewall of the cooper LTZ, one of guys had two tyres replaced under warranty.
Who has upgraded their Tyres on a VX or Kakadu?
Originally posted by Hutch View PostGuys, just reading a thread on Lcool about splitting/ cracks in the sidewall of the cooper LTZ, one of guys had two tyres replaced under warranty.
Just checked mine and it's only on one tyre and the splits seem fairly superficial.Last edited by KAKADAZ; 14-06-2012, 11:59 PM.2010 Kakadu with all the usual stuff.... Build up thread below
yeah the guy at Total Traction Tyres was going to call around and see what he could find with a +15 offset
didn’t take any pics, we just swapped out the front right tyre and i swang the wheel full lock left and right with lots of clearance.
I wouldn’t mind finding some 8 or 9 inch rims if I’m going after market.Last edited by BobTheMonkey; 15-06-2012, 07:35 PM.[B]2012 - 150 VX[/B]
Been looking on and off now for some rims, from what I can tell I should be able to fit 17x9 with a 0 offset. As long as that fits under the guards. That will give me +25mm on each side.
Anyone know of some basic 17x9-0's? Or even anything between that and 17x7.5+15s
http://www.procomp.com.au/Default.asp?MenuId=WHEEL_0098
These come in 17x8+0s
http://www.tech9tyres.com.au/wheels/detail/classic-ll
17 x 9+0 6x139.7 - $345.00
difference:
17x7.5+25
17x9+0
Inner Clearance: 6mm MORE (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 44mm (position of the outside edge of the wheel)Last edited by BobTheMonkey; 18-06-2012, 07:38 PM.[B]2012 - 150 VX[/B]
Bob, moving out 25mm is a big change, I have 7mm on wheel and 5mm on the tyre and are fairly close to the outside of the guard, also u need to check the regulations in your state re wheel track Increase, just some food for thought.[b]Rob[/b]
Yeah, from all I read is you can move 50mm total? But I'm unsure how that is calculated.
The VX comes with 18x7.5E25, 17x7.5E25 (GXL rims) rub on the swaybar which I had fitted by the dealer.
17x7.5E15 (FJ rims) fit nicely but they are $1150 a wheel, and Toyota isn't keen to fork out that kinda money even tho they made the mistake.
From what I understand the wheel can't stick out past the guard, I'm going to still put the same rubber which is 265/65r17 which is rated upto 9.5in rim.
From what I understand is the offset can't be more the 25mm each side which is why 0 would be the max. However does the width of the rim also come into play.[B]2012 - 150 VX[/B]
I am pretty sure it is measured from the centre of the rim, I would be more worried about them sticking out!! But anyhow just giving some ideas to you.[b]Rob[/b]
