Results 1 to 4 of 4
Thread: 1KD-FTV
    Jul 2010
    Dominican Republic
    12
    1KD-FTV
    my engine is consuming more oil than ussual.... almost 1/4 each 2 weeks or so... its not leaking cause i would had noticed it. I've noticed the high consuming happens when i travel short or long trips.. any idea what could be causing this consume? if anybody could give me any info.
    I've heard rumors that the 1KD-FTV after 100k gives cylinder head issues, but my prado has only 110k in the clock, no engine power loss , compression loss, weird noise or anything ... replaced the air filter, replaced the oil and filter but the consume continues.....
    http://img717.imageshack.us/img717/5...1101211747.jpg
    2001 VX TD. Jaos front defense, HID lights ,1kzte , Semi-Stock.
    Advanced Member Davros's Avatar
    Nov 2009
    Sydney NSW
    764
    Re: 1KD-FTV
    What grade of oil are you using?
    Feb 2007
    South Australia
    3,092
    Re: 1KD-FTV
    I thought you had a 1kzte engine in your Prado? (previous posts)
    Mick
    Jul 2010
    Dominican Republic
    12
    Re: 1KD-FTV
    Thats because i actually own 2 prados , a 90 series with the 1kz and a 120 series with the 1kd
    The oil i use is Kendall Super D Sae 15w-40 1/4 (one quarter)
