Prado Rim Size & Offset Database
This is a sticky topic.
  • Not sure if you're changing rims on the van to 17". If so you can fit 245/70R17. Might be able to score the rims from a GX Prado.
      Go for a smaller positive offset. If you have a 120 the standard offset is P30 so you could go to a P15 or P10 to give clearance and it would be OK on the Prado in an emergency. Similar story for the 150 but it starts at P25.
      I have a Tvan and the suspension is different for P0 and P30. Luckily mine is suitable to run Prado wheels on.
      So p10 would give me 20 mm clearance on the van, which is good. Could I use one of those on the car with the standard 265/65/17 on the other side, (front or rear?) if I do my spare on the car and is it ok front and rear, bearing in mind the cars independent suspension?
        Yes I am.
        Would those be the 6" rims?
        • Originally posted by Cloud View Post
          Yes I am.
          On the 150 GX, they are 6.5" wide with +15 offset. You don't want the 120 GX 6" +50 rims.
            To get you out of trouble I see no problem but if you change all your wheels to P10 would mean increasing the vehicle track by 40mm which is probably more than you are allowed legally. Most states limit the increase to 25mm.
            • Thanks fellas.
              Looks like the GX 6.5" are the answer - as long as they'll be ok on front or back to get me to a tyre shop - which, of course, could be 400 kms away
              • Ha
                Solving the problem is one thing but try finding the bloody things. Had a bit of a Google and been thru speedy wheels and the like but no joy. Might give the local dealer a bell in the morning and see if they can get them in.
                • Saw at least 6 listings on Gumtree. Depends on where you are.
                  Dealer will charge you 1 for the price of a second hand set.
                  • Sydney - Newcastle
                    Only 265/65/17 on there
                    • Here are some rims with tyres, although the tyres would need to be checked if they are still within "date".
                      WA - http://www.gumtree.com.au/s-ad/welsh...els/1124747450
                      NSW - http://www.gumtree.com.au/s-ad/galst...-x4/1124731318
                      • Thanks for that, mate.
                        So, they are the 6.5" ? I didn't recognise that by the description.
                        Much appreciated.
                        • Yes they are. The front face of the rim has a slightly different pattern to the GXL rim.
                          • Thanks for your help pal - you're a legend. I'll have a look at those later this week.
                            • Got the set last week
                              Axle stub intrudes a bit so will have to get a deep cap to accommodate. Those speedy ones rust as soon as you look at them. Just have to keep on top of it. Otherwise, just the job.
                              • Post some pics
