Prado Rim Size & Offset Database
  • Some weights are here to give you an idea
    http://www.pradopoint.com/showthread...tyres-and-rims
    • Oops not 20kg more like 12........ Oops.
        Thanks guys!
        PS: I thought 17" TRD heavier then standard 17" alloys?
        Prado [I]Grande[/I] 4.0
        • Want RIM will fit - little confused on offset
          Hi Guys,
          Read up on the threads here but trying to get around what the standard offset is.
          120 Series
          GX/Standard 17x6" ET50
          GXL+ 17x7.5 ET30 <------ Is this the offset?
          The rims that I wanted, MT Sidebiter have a P0 offset. So the guy was saying it will stick out 30mm which is illegal.
          Does this make sense?
          So does this mean I have to look for a rim that has a 30mm offset?
          • Yes the standard offset is ET30, P30, +30. If you put on a P0 wheel, the centreline of the wheel will move outwards 30mm. However, if the wheel is say 8", then the outside of the rim will be a further 0.25" outwards.
            If you want to stay legal, most states will only allow a track increase of 26mm. Half this and you will only get a change of 13mm in offset allowed. So for the 120, the legal wheel offset is ET17 to ET30.
            • Thanks for this mate!
                Toyota Prado Standard Rims
                120 Series
                • GXL+ 17x7.5 ET30
                150 Series
                • GXL 17x7.5" ET25
                I have a 150 GXL and my dad has a 120 GXL. He has a set of Cooper ST/MAXX tyres on a spare set of 120 GXL wheels that he's not using (nor likely to use in the near future) and I'm wondering if I can pinch them.
                I understand that 120 GXL wheels aren't legal (but will fit) on a 150 GXL because the track decreases by 10mm (ET30 vs ET25).
                From reading the whole thread I gather that increasing the track by 10mm is ok - so 150 GXL wheels should be legal on a 120 GXL. Is that true?
                If that's the case I might swap his Cooper tyres across to my rims and try to source some spare 150 GXL wheels in case he wants his tyres back for a trip!
                • Yes, Peter. You've got it the right way round
                  • +25 offset on 2008 120 GXL - ok?
                    I have an 08 GXL 120 with standard alloys with +30 offset.
                    I am looking at some aftermarket alloys and they come in +25 and +40 offset. (Dynamic Hi8 in black)
                    Am I correct in selecting the +25 offset which is a slight increase in track width?
                    Pretty sure I am right but would welcome confirmation.
                    Lodgey
                    SEP08 GXL D4D AUTO & other bits and pieces.....
                    • That sounds about right. What diameter and width is the new wheel you're looking at? That could factor in a change in wheel track
                      • Thanks.
                        They are 17x8 with offset +25.
                        Lodgey
                        • I don't know exactly but I think that would keep the stock wheel track.
                          • Track is changed by a different offset regardless of rim width, so a 10mm increase in track which is fine.
                            • I just measured the wheels that came with the camper. I thought they were P30 for a 120 but the wheels are the same as above. dynamic 17x8 P25. So I could have left these on the camper... But the alloys look better and have KO2s and not KOs.
                              • Thanks Andrew for feedback.
                                I have new camper trailer approx 2 weeks from pick up and it has
                                dynamic Hi8 17x8 with p25 offset (black) and I am thinking about putting the same on the Prado.
                                Lodgey
