Prado Rim Size & Offset Database
    I've just had some new Allied Hammer wheels put on my 150 GXL and they look great.
    Photos on my buildup thread.
    Cheers, Sam.
    150 GXL V6 Auto. BFG AT 275/65/R17, ARB Deluxe Winch Bar, OME 2" Lift, Firestone Airbags, Dual Batteries, GME UHF, Rhino Sportz Crossrails and Platform Rack, ARB Awning, Redarc Brake Controller, Rear Drawer System, Safari Snorkel, New Toyota Mudflaps, Kaymar 'Wheel on Door' Bracket, ARB Under Vehicle Protection, IPF 900XS Spotties, Allied Hammer Wheels. Disclaimer - I am an ARB employee. [B][URL="http://www.pradopoint.com/showthread.php?17348-Sam-s-150-V6"]Buildup Thread[/URL][/B]
      Added this tyre/rim calculator to the first post. Best I've seen so far.
      http://www.rimsntires.com/specs.jsp
        I notice that the 150 series GX is fitted with a 17x6.5 alloy wheel now. Did Toyota ever make a 17x6 alloy rim for the 120 series, or are all 120 series alloys 17x7.5?
          The 120 17x7.5 were alloys or steel. The narrower ones were all steel.
            Thanks, I have a 120 series Prado brochure that lists the 17x6 wheel but doesn't state whether it's steel or alloy. The same brochure states the track to be 1535mm for the standard 120 with 17x6 rims and 1575mm for the GX, GXL, VX and Grande with 17x7.5 rims. If the offset is ET15 for the 17x6 and ET30 for the 17x7.5 then the figures in the brochure don't make sense. Shouldn't the ET15 wheel give you a wider track?
            The 150 series specifications make more sense: 1605mm GX, 1585mm GXL, VX & Kakadu.
              Maybe the brochure is wrong.
                Yep, 1575mm is the correct track for a 17x7.5 ET30 as measured on my Grande. That would make the track 1605mm with a 17x6 ET15. Now that makes far more sense and agrees with the 150 series data.
                  The brochure must be wrong. If you take the GXL track is 1575 then add 60 that gives you 1635 hub face to hub face. The 17 x 6 wheels (definately only steel) are +15 offset so the track is 1635-15-15 = 1605 as per the 150. I checked the 08 brochure and sure enough it states 1535 as track. Wonder what the earlier brochure had listed?
                  OK answered my own question, found the pdf version... GX and GXL listed, same figures as 08 brochure for std and GX/GXL/...
                  Tyres
                  225/70R17 265/65R17
                  Rims
                  6Jx17 Steel 7.5JJx17 Alloy
                  Overall Length (mm)
                  4810 4850
                  Overall Width (mm)
                  1790 1875
                  Overall Height (mm)
                  1850 1865 (no roof rails)
                  Wheelbase (mm)
                  2790
                  Front & Rear track (mm)
                  1535 1575
                  mjrandom
                  Out of control poster!
                    I checked the Toyota owners manual and on page 324 it states a "Front and Rear tread of 1535 With 225/70R17 tires" and "1575 With 265/65R17 tires".
                    If this is correct, then the offset of the 17x6 GX/Standard steel rim is actually ET50.
                    Peterpilot
                      Jimmy has a GX and it sure does look like an ET50 offset rim. Hmmm...
                      http://www.pradopoint.com/showthread...l=1#post356895
                        Look.
                        Just tell me what great looking rims I can fit on my 120 2009 Grande. I like the look of DC2's but they are a no-go.
                        I admit I cannot read any of the charts, I am tyre size dyslexic and incompetent. Every time I try I feel half pregnant!
                          I was thinking the same thing, looking at how the centre of the GX steel rim is almost proud of the tyre sidewall. I wonder if Jimmy or anyone else with a GX or Standard with 6" steelies would be able to measure the track from tyre tread centre to tyre tread centre and determine what the actual track is. Or perhaps Toyota could enlighten us with the offset of the 17x6 steel rim.
                          Looking at this wheel offset calculator, a 6" rim with an offset of ET50 would sit just about flush on the suspension side as a 7.5" rim with an offset of ET30.
                          The implications for wheel choices for NSW Prado owners becomes limiting if the 7.5" ET30 rims are the widest factory offset available on a 120 series. Current NSW regulations restrict rims to offsets that will not increase track by more than 25mm, which means offset would be restricted to ET30 to ET20 (ET17.5 theoretically speaking). At an offset of ET20, any rim wider than 8" would reduce clearance to the UCA when compared to the standard rim, further restricting rim choice.
                            Look.
                            MLC, you just want someone else to do all the work for you.
                            Try Allied Wheels:
                            Allied Hammer 17x8 ET20
                            Allied Wasp Black 17x8 ET20
                            Or CSA Wheels:
                            CSA Jackal 17x8 ET25
                            CSA Tanami 17x8 ET20
                              I think the law allows you to make modifications according what is on the tyre placard. Perhaps on the GX's tyre placard, it will list both the GX and GXL wheel and tyre spec.
                                Yes, the GX and Standard can go to the 17x7.5 ET30 but if the the offset allowing the widest track is now ET30 instead of ET15, then the limit for maximum allowable track is 30mm less.
                                In other words, using NSW regulations: If the widest factory track is 1575mm for the 120series, then the maximum allowable track increase of 25mm makes the maximum track 1600mm for the 120.
                                The 150 series has a widest factory track of 1605mm, add 25mm maximum track increase and the maximum track for the 150 is 1630mm.
                                I bet MLC's head has exploded by now.
