Alright! I'm in the process of getting my dual battery setup and have had a headache searching through several different threads for solutions on which tray and battery to get. So I thought I'd create a thread with all our dual battery threads to make it easier for other members when they get around to it. While we are well aware of the issues with the aircon pipe and power steering reservoir, here are the various documented installs that I have found:
Tray: ARB
Battery: Supercharge Amptech D50Z
Comments:
- No bending of the aircon pipe
- Used a small bracket to gently (I mean gently) push the pipe out a little.
- RedArc Isolator was used
- Link: viewtopic.php?f=38&t=10845&st=0&sk=t&sd=a&start=12 0
Tray: ARB
Battery: Optima 55A Yellow top
Comments:
- Redarc BCDC1220 was used.
- Link: viewtopic.php?f=38&t=12846
Tray: ARB
Battery: SuperCharge Allrounder MRV50 259x273x202
Comments:
- No relocating the aircon pipe
- Link: http://www.pradopoint.com/viewtopic.php?f=50&t=11827
Tray: ARB
Battery:
- Century NS70X (cranking 580CCA), size: 258x172x225
- Century Optima D34 (dual purpose 750CCA/55Ah), size: 254x171x199
Comments: As recommended by ARB
Tray: Sidewinder
Comments:
- Link: http://www.sidewinder.com.au/page190.html
- Slight relocation of aircon pipe required.
- Relocation of power steering reservoir required (for Petrol model only)
Tray: Sidewinder
Battery: Amp-Tech D50Z
Comments: Slight bend of AC pipe required.
Tray: Sidewinder
Battery: 60ah Supercharge Allrounder
Comments:
- Petrol model
- Smaller battery as power steering reservoir was not relocated
Tray: TJM Dual Battery Frame
Batery: - Supercharge MRV70 105AH (Diesel install)
Comments: Used with a Projecta 150 Amp Dual Battery Controller
Tray: Unknown
Battery: Federal 75AH DC24
Comments:
Batteries that are assumed to require bending the aircon pipe:
Tray: Unknown
Battery:
- Trojan 100ah 275x170x200 note: battery base is 260 (Petrol install)
Comments:
Link: http://www.pradopoint.com/viewtopic.php?f=50&t=9701
Battery swap method:
Tray: Sidewinder kit
Comments:
- Factory battery relocated to driver side tray
- Supercharge MRV70 installed in passenger side tray
I will add more builds as they come or when I am notified. I hope this has helped someone.
Tray: ARB
Comments:
Tray: ARB
Comments:
Tray: ARB
Comments:
Tray: ARB
Battery:
Tray: Sidewinder
Comments:
Tray: Sidewinder
Tray: Sidewinder
Comments:
- Petrol model
Tray: Unknown
Comments:
Tray: Unknown
Battery:
Comments:
Comments:
