Rattle in rear area - Door?
    I found it was the wedge type thing that that sits where the door strike is, it needs to be adjusted up to allow for the movement caused by the weight of the spare.
      I had a rattle coming from the rear and turned out to be the factory inverter had come a little loose on one of the bolts behind the RHS cargo bay skin.
      Was actually an easy find which is unusual for any rattles in a car...
        Originally posted by sleeky5 View Post
        Great outcome. The only thing I didn't try was loctite. Let me know how it stands up after the next expedition.
        Sure will. Bike rack on the Rear wheel and camper trailer trip for three weeks coming up should be a good test.
        2014 VX, White, TJM Bullbar, Xray Vision HID driving lights, Hayman Reese Towbar, Tekonsha P3 brake controller, dobinsons lift, Coopers LT ATs
          Hi, I had a very similar and annoying rattle in the back of my Prado, took me a while to locate it after I was certain it was my Tailgate as well.
          turns out the noise was coming from inside the RHR quarter panel area, there is a module held to the inside of the body by 2x 10mm bolts.
          I found that where this bracket mounted to the body had cracked the captive nuts and was flexing causing it to rattle.
          I relocated the module to another spot in the same area and Presto.....fixed! I did take some photos, I will have to find them.
            Sounds like it was the same issue I had with the inverter, one of the mounting locations had actually cracked.
            I was lazy and chucked a bit of silicon and some washers into the mix, squeaking stopped though!
              Rattle at back door 150 Vx
              Hi!
              Had a verry loud rattle at the back door. Turns out to be the lock that went dry, so greased the lock catcher and amazingly a verry quite car! Absolutely amazing!!
              Removed spare wheel etc..... tools ...... opened door and at the end it only needed a little bit of grease on the catcher !! 🙈😉
              Hope it helped !
                Hey guys. So I had a creaking noise in the rear of the car, coming from the wheel carrier. Pulled the wheel off today and found that the carrier has cracked. Not sure if you can see it that well in the photos.
                  I had the rattle in rear door area. It was a black plastic part next to rear wiper in the rear spoiler. Lock was lose so i put double side tape around lock n fit back in.rattle gone. But still tring to fix the noise coming from rear seats when no one sit there. Preety annoying. Does anyone have the same problem and any fix for it. Cheers
                    I think Toyota have a fix for the rear seats from memory. Only affects older models.
                    [/CENTER]
                      so brought this damper kit from toyota. But does anyone know how to fit this thing. Spare part manager n service people dont know at toyota how to fit. Any clue thanks
                      http://i1162.photobucket.com/albums/...pspxdfbywo.jpg
                        Ok found it how to fit. But F****** toyota charge me $84 for just the $2 part. Its just extra insulation on same part. Bloody rip off. N its a special order cant return it.
                          Did it work?
                          [/CENTER]
                            Another update. Apparently prado doesn't come with that. I thought it does n only difference is the insulation( was looking at Lexus gx460). So when i pull the seat apart there was no seat damper. Now there is one. I haven't went for drive but dont think so it will fix the problem. Let u now tomorrow. win or lose.
                              Originally posted by Symo View Post
                              Did it work?
                              Yes it does work. No more rattling seat.
                                Another update after seat rattle fixed found another squeeze noise coming from same side. That was rear passenger door trim. So spray wd40 between door trim n door. All silent n now i can concentrate at front while driving.
