Recovery Points
  • Recovery Points
    I know there is a thread out there about recovery points for the front but for the life of me I cannot find it. Thanks to google I found it... http://www.pradopoint.com/showthread...0-Series/page3
    Just doing my usual Sunday night troll on ebay and noticed FNB4WD selling new Outback Ideas Recovery Points on Ebay for the 150...
    Link here http://www.ebay.com.au/itm/Outback-R...c#ht_826wt_907
    Now I thought, finally some are available, then I read this...
    PLEASE NOTE THESE ARE NOT A RATED RECOVERY POINT AND SHOULD BE USED ACCORDINGLY ALTHOUGH THEY ARE QUITE STRONG THEY ARE NOT A RATED RECOVERY POINT
    WTF? In my opinion I am better off sticking with my OE ones as it appears they mount onto the same spot. Just my 2c.
    Back to Ebay, cheers Daniel
    Rogerthatv2
    Daniel
    My understanding is that nobody is providing “rated” recovery points any more due to the legal implications if one was to break. I think this is about as good as we are going to get and would be rated if we (all people) were not trying to sue each other to make a quick buck.
    Stephen Bloomer
    I did have - 2010 GXL D4D Auto, ARB bullbar, rails, sliders, winch, 40mm lift, Brown Davis bash plates and long range tank
      Mmm, whilst I agree with your comments Outback Ideas and other suppliers make rated points for other vehicles, including the 120. TJM, ARB etc do not make recovery points (or build them into thier bars) any more due to that reason but there are still people out there making them and clubs requiring there installation prior to joining... I was hoping we would get one soon for the 150 however I am happy to stick with my equaliser strap and OE front points for the time being.
      Rogerthatv2
      Daniel
        Richoson has some big new recovery points made for the 150, not sure if he has posted the photos yet but I have seen them.
        Pm him.
        Hutch
        Addicted PP Member
        [b]Rob[/b]
          some rated points would be extremely useful...
          2011 150series GXL
            Richoson sent me these pics, uploaded on his behalf. New recovery hoos for the 150.
            [b]Rob[/b]
              The Ebay link are not the Outback ideas Point. Apart from the picture being totaly wrong!
              The Point Richoson has are the Outback Ideas ones (genuine) and they are rated fairly high.
              We sell the Outback ideas one and we can post or your Local ARB store should be able to get them from me if you like!
              Giles
                Thanks Giles, do you know if they will fit with a TJM bar? If so I shall give you a call tomorrow to order a set. Thanks.
                Daniel
                  Giles,
                  Have you found a way to post fit the recovery points to the ARB bar?? without removing the bar?
                  2010 150 D4D Kakadu, Graphite, Toyota tow bar, Tint, Mats, Headlight Protectors, Redarc dual battery and Brake controller,Sahara Bar,Safari Snorkel,Icom440,OME suspension,Steinbauer module,Genesis HID lights.
                    Im pretty sure it will! but we would have to take a look at it! I thought both the ARB and TJM bars went on very much the same way.
                    We need to confirm this tho.
                      Originally posted by KJA View Post
                      Giles,
                      Hey Ken,
                      No it has to come off.
                      Which is a pain but it's all we have to work with!
                        Yes they will fit with a TJM bar & the TJM bar does not have to come off to fit them.
                        But I did have to measure & drill a hole in each one as the rear bolt securing the TJM bar is in a different spot than where the ARB bar is secured.
                        However, be careful with the nut, because when you undo it it will fall inside the chassis. If you have a close look you may find that a bit of wire has been welded to the nut to assist, check just inside the inspection hole as the wire on mine had been cut off & poked inside the chassis.
                        Good luck!
                        REV
                          Rev
                          Would it be possible to post a pic or two. I'm about the have a T13 TJM bar fitted and I'm interested in fitting recovery points.
                          Pinko
                          PINKO
                          Prado 150 D4D, Bilsteins, OME Coils, Air Bags, TJM Bulbar, Avenger 9.5 winch, Lightforce HGT's, Kaymar rear bar, Sidewinder Dual Battery Kit, Drifta Draws, Window Tint, Transmission Cooler, Scanguage, Caterpillar Water Separator.
                            Hi Folks
                            Just noticed on the photos fo my recovery points that somebody must have got under my car and scratched the paint off my bash plates
                            Regards, Richo.
                              Good luck!
                              REV
                              Thanks for the info Rev on the TJM bar.
