Recovery Points
    I took the plunge and ordered a set of the Outback Ideas recovery points. They arrived today and I was happy to see a modified nut welded to a small plate and piece of wire that should help when installing them without removeing the bar entirely.
    I'm going to have a go at fitting them on the weekend. Hope all goes well.
    VXWesty
    [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
    [/SIZE]
      Hi VX Westy
      I have them installed and lets hope that we never need to use them unless we need to pull another brand of 4ourby out.
      See ya on the tracks, Richo.
        VXWesty
        hi VXWesty,
        could you plz measure the size of that black backing plate that is welded to the nut and the also length of the wire thats is welded to the plate so i can see if this will also work on my 120,
        thanks PradOz
        [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
        ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
          Hi PradOz,
          The plate is 27mm x 47mm and the wire is 260mm long.
          VXWesty
          [/SIZE]
            are these offered on ebay? i need to calculate shipping to my country
              Yes, you'll find them on eBay.
              VXWesty
              [/SIZE]
                I got mine on eBay from FNB4WD - $120 I think they were and I asked a couple of questions and he was really helpful. They are nice and solid. I have the standard plastic bumper and didn't look forward to removing it to fit tow points, but then discovered the wire is good, feeding the plate down the chassis rail from the square cutout in the chassis then trying to hold it firm enough to get a bolt through the tow point and lined up with the nut in the plate was a bit fiddly.
                Very happy, much more sound and reassuring than the tie down hooks
                  Originally posted by Matty & Loz View Post
                  Be advised, FNB4WD sells genuine Outback Ideas products. As per moderator discussions with Outback Ideas and FNB4WD.
                  Buyers beware of statements made by members on proadpoint regarding products.
                  Are these the ones everyone is buying and having success with? Will they clash with an ARB deluxe steel bar?
                  http://www.fnb4wd.com.au/index.php?r...roduct_id=1296
                    I put some on my car last weekend... Post #27
                    http://www.pradopoint.com/showthread...o-150-VX/page3
                    I'm pretty sure they will fit with the ARB Deluxe, but bet to check with other PP members.
                    Jeff
                    [SIZE=3]Jeff[/SIZE]
                      These ones are branded as Boss4, I'm not sure who makes them. I would also like to know if they would clash with a TJM T13 bar.
                      I also found these ones as an alternative :-
                      http://www.ebay.com.au/itm/TOYOTA-PR...item3f1b9210d2
                        They look the same shape as the Outback ideas ones, close enough in fact that they may just be rebranded. The outback ideas ones fit with the ARB Deluxe winch bar. I've got a picture in my rig build up thread of them fitted. I suspect these will be the same design and would also fit with the bar.
                        Tiny
                          I'm actually liking those Road Safe 4WD ones I found on eBay; the elongated holes on the front seem well suited to use of an equaliser strap. The seller Everything 4WD has a storefront in Cranbourne Vic so it shouldn't be too hard for me to have a gander at them before purchasing a set. I was advised they would fit my bar and can be self-installed; like the OI ones it's a little fiddly I'm told.
                            Love to see some pics when you get them on fido. Haven't seen any on a tjm bar yet.
                            150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
                            [URL="http://www.pradopoint.com/showthread.php?18807-ages-150-VX-D4D-black"]My Rig Buildup[/URL]
                              I'm following up with the manufacturer to confirm fit so stay tuned!
                                I have read the discussions on the recovery points in both the 120 and 150 threads and I haven't come across any mention of air bag compliance, unless I have missed it.
                                I am curious if there are crumple or compression points in the chassis rail that are part of the air bag system that might be being bolted over and "reinforced" with recovery points. I don't know how the bull bars are made to comply with air bag requirements, but I am wondering what effect the bolt on after market recovery points may have on air bags deployment and subsequent insurance claims.
                                Paul
