Page 2 of 2 FirstFirst 12
Results 13 to 21 of 21
  1. #13
    Join Date
    Jan 2008
    Location
    Sydney, NSW
    Posts
    894
    120 series Alloy Wheel Corrosion?
    Hi All,
    Has anyone experienced the paint bubbling on their alloys. My unused spare which has been under the hard wheel cover for 3.5 years of 4 years of ownership from new is the worst with one of the rims on the car showing it as well. Is it a warrantable item (I have Toyota extended warranty). The photos were taken from my phone so could be better but you should get the idea.
  2. #14
    Join Date
    Jan 2009
    Location
    Umina Beach, NSW
    Posts
    697
    Whilst I do not have the same issue, I have some advice on the Toyota Extended Warranty.
    It only covers 'lubricated parts'. At my last service, I was advised that the rear shocks are leaking and need replacing, I told them to go ahead as its covered by my extended warranty. Thats when I was told the above. Was I happy? Nope, not really..
  3. #15
    Inactive member.
    Join Date
    Sep 2012
    Location
    SOUTH OZ
    Posts
    532
    Blog Entries
    1
    Ive seen this on anodized and powder coated parts before.......
    There is a chance with salty moist air coating these types of products around a join or crease area that it gets in...then over a period of time the aluminium underneath oxodizes....Alloy rust per say....or it can be that that part of the wheel was not prepped right at the coating phase...ultimatly...same result with two causes
    Whats the forum think?
  4. #16
    HKB Electronics
    Join Date
    Jul 2009
    Location
    Melbourne, VIC
    Posts
    1,520
    Quote Originally Posted by MDSimpson View Post
    I have a Toyota extra care factory extended warranty and the warranty does not have any such exclusions, the warranty states "we will repair or replace free of charge any Toyota component found to be defective in material or workmanship under normal operation and use in Australia with the exception of any item listed under "What your warranty does not cover" shockers are not excluded?
    I recently had the engine mounts changed under the warranty and wouldn't class these as "lubricated"
    Regarding the corrosion to the wheels, this has been raised somewhere else if you care to search, I checked the extended warranty and it states that corrosion caused by scratches or chips is not covered, I would therefore assume that other corrosion would be.
    Leigh
  5. #17
    Out of control poster! mjrandom's Avatar
    Join Date
    Jan 2008
    Location
    Samford
    Posts
    5,931
    Agree Toyota extra care covers pretty much the same as the factory warranty. I have had the water pump and injectors replaced under extra care so the $1800 it cost me was worthwhile. There were some 'dealer' warranties being offered for lots less that don't cover much at all. Some limit the total spend per claim and then cap the total spend in a year. Some exclude parts as you have found. I have no complaints with extra care.
    Bluestorm mafia and maybe one or two other vices.
    My 150: http://www.pradopoint.com/showthread...-D4D-automatic
  6. #18
    Addicted PP Member D4D's Avatar
    Join Date
    Jan 2008
    Location
    Land of Plenty
    Posts
    4,086
    Yes it is a known problem, whether the dealer does something will depend on if you have extra care or dealer warranty.
  7. #19
    Join Date
    Jan 2008
    Location
    Sydney, NSW
    Posts
    894
    Quote Originally Posted by LeighW View Post
    Leigh
    I had my initial enquiry knocked back yesterday for the corrosion on the rims. I have read my PDS and on page 14 it states under what you are not covered for
    "Wheels, tyres, paintwork, panel and bodywork and their components (including moulds, weather
    strips and seals), cosmetic finishes, components made of glass and associated parts, all decorative
    or trim covered components (including, cup holders, ashtrays and interior compartments);"
    In addition on page 15
    Your policy does not cover parts that fail because:
    of corrosion, electrolysis or rust.
    So has anyone had these rims replaced under extended factory warranty.
  8. #20
    Quote Originally Posted by MDS69 View Post
    Hi All,
    I have exact same issue on my 120 (2007). what did you or anyone else do?
    Do you have the paint color reference for those alloy wheels?
    I'd like to sand and paint. Any advice is welcome. Thanks.
  9. #21
    Join Date
    Jan 2008
    Location
    Land of Plenty
    Posts
    4,086
    Quote Originally Posted by Mamadou View Post
    Full strip and repaint metallic black. It is fiddly if you want to keep the machined finish.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
