Alloy Wheel Corrosion
  • Alloy Wheel Corrosion
    We have a 2008 Grande D4D with the smokey alloys. All 5 wheels are showing corrosion bubbles and it is getting worse. Worse still we only notified Toyota just AFTER our warranty expired so they told us bad luck. They say it may be because of the product we wash the car with. We just use a Turtle Wax car wash so I dont bu that. I dont see any similar threads so I am I just unlucky or is this a common issue for polished alloys.
    2008 Grande Silver Ash D4D
    ARB Deluxe Bar
    9000lb Warn Winch
    IPF Lights
    Safari Snorkel
    Dual Batteries
    BF Goodrich All Terrain 265/70/R17
    Mate, I've never had any problems with Turtle products. Your not near salt air, are you?
    Bazza.
    [i]I'd rather laugh with the sinners than cry with the saints![/i]
      We live in Coffs and are near the coast so we do get salt air. We keep the car clean and wash it when we can. We get an Endrust treatment every year on the vehicle so no problems there. I have had a few cars but never seen corrosion like this especially for a 3 year old vehicle.
      ARB Deluxe Bar
      9000lb Warn Winch
      IPF Lights
      Safari Snorkel
      Dual Batteries
        Mate, if you dont get any satisfaction fro Toyota you might want to sand that corrosion off, give it a coat of etching primer, paint and then clear, before it gets worse. I would only treat the areas effected and keep the repair as small as possible. If your close to the beach, after you've washed and dried them, you might also want to spray the wheels with a light coat of anti-static silicone. This will protect them and the wheel nuts very effectivly.
        Bazza.
          My alloys have the same bubbles forming in places. I don't live near the ocean so it might be a quality control issue with the finish on the wheels.
          2004 GXL V6, 5 Sp Auto
            I spoke with someone in the Lismore/Casino area a while ago with the same problem... much worse though. Local dealer gave her the same lame blame game... "you haven't been taking sufficient care of your genuine Toyota alloy rims!"
            Another Toyota brain fart... just fix it guys (Toyota) and not make a joke of what is a very good product over all.
              Common problem, go harder on your dealer or contact Toyota direct
                Glad to see I am not the only one having corrosion issues. This is my 3rd 120 series and the only one I have ever had corrosion issues on the alloy wheels with. The vehicle has been used in the same conditions and washing products so will be hitting up toyota hard over this!
                  Had the same problem. Live near Coffs but on a property & cross two creeks every day so thought this may have contributed. Fortunately I spotted before end of warranty and after pushing my case very hard Toyota replaced. New ones are 6 or 7 years old with no issues so far so definitely a quality issue.
                    My 03 Grande lived by the ocean for the first 8 years of its life until i just bought it and there is no corrosion whatsoever on the wheels.
                    Was parked outside for a lot of its life too and not kept particularly clean either.
                    Thats now all changed though
                      Mine is 03 Grande, first lived Northern Beaches .Sydney,now in Coffs Harbour & all wheels have corrosion problem.
                      03 Grande, V6 AUTO.Red Metallic, Sovereign bar,Narva driving lights, GME uhf.
                      Brtidgestone D697 ltrs,(got more than 75000 kls out of D694's) Black Widow Rear drawers & Cargo barrier,with shelf & divider..Elec Brake controller,now tow a 24ft "Spaceland" 2012 caravan.
                      [B][I]Bitumen - A blatant waste of taxpayers money![/I][/B]
                        I have an 06 d4d with the same problem. It goes to Fraser Is 2-3 times a year but we always wash them. I thought "alloy" wheels would not corrode. Does the impact on the wheel's integrity? or is it just an ugly sight. It looks like the corrosion is under paint. If I sand them back will you see the difference?
                          120 series Alloy Wheel Corrosion?
                          Hi All,
                          Has anyone experienced the paint bubbling on their alloys. My unused spare which has been under the hard wheel cover for 3.5 years of 4 years of ownership from new is the worst with one of the rims on the car showing it as well. Is it a warrantable item (I have Toyota extended warranty). The photos were taken from my phone so could be better but you should get the idea.
                            Whilst I do not have the same issue, I have some advice on the Toyota Extended Warranty.
                            It only covers 'lubricated parts'. At my last service, I was advised that the rear shocks are leaking and need replacing, I told them to go ahead as its covered by my extended warranty. Thats when I was told the above. Was I happy? Nope, not really..
                              Ive seen this on anodized and powder coated parts before.......
                              There is a chance with salty moist air coating these types of products around a join or crease area that it gets in...then over a period of time the aluminium underneath oxodizes....Alloy rust per say....or it can be that that part of the wheel was not prepped right at the coating phase...ultimatly...same result with two causes
                              Whats the forum think?
