I have compiled a database of manufacturer supplied after market specifications on struts, springs and shocks for the Prado 120 into a single thread.
Approximate and measured standard Prado 120 & 150 data is included for comparison purposes. Feel free to post any additional manufacturer supplied suspension data and I will add it to the codes.
Thanks to AMTS, the database can also be downloaded in Excel format here:
https://app.box.com/s/q01btk5zdj5xp5nx53nb
Front Strut Data
# includes shroud spacer
Front Coil Data
Rear Shock Data
Rear Coil Data
*Data converted from N/mm to lb/in using this Spring Rate Converter:
http://www.hraefn.net/projects/spring_rates.php
N/mm can also be approximately converted to lb/in by multiplying by a factor of 5.71
Ironman strut installation guide can be found here: http://www.ironman4x4.com/pdfs/suspe...structions.pdf
General suspension guidelines:
Many states, including NSW, limit suspension lifts to 50mm maximum before engineering certification is required.
Always retain a minimum of 60mm downward suspension wheel travel following a suspension lift.
It is a good idea to have 30mm of rake - i.e. the rear is 30mm higher than the front.
Never fit a shock or strut that reaches minimum compressed length prior to reaching the appropriate bumpstop first.
Never fit a shock or strut that allows components such as brake lines, cv joints and sway bars to limit suspension travel before the shock or strut reaches maximum extension.
*** Other very useful suspension info:
OEM strut and shock lengths for Toyota 4wd vehicles
OEM coil spring rates for Toyota 4wd vehicles
Bilstein struts and shocks Lengths and Valving
120 and 150 series IFS after-market strut Valving as a function of Coil Rate
Optimal Rear Valving and Coil Rate in the Prado
Coil Spring Preload: What is it and what can we do with it?
IFS Strut spacers and Coil spacers: How do they work and what can they break?
The effects of motion ratio on IFS valving
Lift vs Droop for various open length struts on Prado 120 IFS
Ball joint and CV bind open lengths on the Prado 120 IFS coil out cycling
OEM droop on factory 120 coils
Can you get coil bind/solid coil on the 120 Prado IFS?
Vehicle lift as a function of coil free length for 120 series Prado
Critical Damping in Prado 120 struts and shocks
Rear motion ratio on 4-link live axle on Prado 120 series
Rear Lower Trailing Arm-Axle Housing Separation on Prado 120
Rear Lower Trailing Arm-Axle Housing Separation: parallel measurements
Main Fuel Tank – rear trailing UCA separation on Prado 120 series
Coil bucket separation vs rear shock open length for Prado 120 series
Rear lift, droop and shock open length variation for 120/150/FJ
Extending rear sway bar links: maximum extension
Optimal valving and coil rate for the 150 Prado IFS
150 series front and rear lift vs coil free length
Seized cam adjusters in front lower control arms
HOW TO: Lower Control Arm Bushing Replacement
Any specific data posted here may be manufacturers approximations or approximate measurements and are to be used at your own risk and as a guide only. All research and any parts fitted or modifications done are the responsibility of the individual. While all care is taken to provide accurate data, I take no responsibility for any errors, injury or damage that may occur as a result.
Front Strut Data
Code:
Front Strut Open Travel Closed Notes (mm) (mm) (mm) Standard Prado 120 541 111 430 Measured GrandeTEMS Prado 120 540 120 420 Measured Standard Prado 150 555 122 433 Measured Standard FJ Cruiser 541 106 435 Measured Standard Hilux 555 125 430 Measured ------------ Bilstein BE5-A480 561 125 436 #P/No 24-104807 Bilstein BE5-A712 560 125 435 #120 Bilstein BE5-D563 575 142 433 #Hilux strut Bilstein 5100 573 140 433 #P/No 24-186711 2007-09 FJUSA/120 Bilstein 5100 571 124 447 #P/No 24-196499 2010-15 FJUSA & Oz/150 Bilstein 24-173032 555 135 420 #150/FJ *no longer imported Bilstein 24-173032-1 570 150 420 #150/FJ *no longer imported Bilstein 24-238762 570 145 425 #120/Hilux *no longer imported CalOffroad 24-218528 555 122 433 CalOffroad 24-218528 575 142 433 CalOffroad 24-218528 595 162 433 Dobinsons GS59-221 548 121 427 Dobinsons GS59-700 548 121 427 Prado 150 strut Dobinsons GS59-220 560 125 435 Hilux strut Dobinsons MR59-50221 560 133 427 120 Front Std Dobinsons MR59-50700 570 143 427 Prado 150 strut Order with 221 shock bush if fitting to 120 EFS 38-5637 560 130 430 Ironman 12710GR 540 132 408 Ironman 12710GR 565 132 433 Measured Ironman 12750GR 552 127 425 Prado 150 Strut Ironman 45710FE 566 131 435 King 25001-261A 565 125 440 A' in P/no = adjustable Koni 82-2522 555 125 430 Koni RAID 88-1712 548 117 431 Koni RAID 88-1712SP 563 133 430 KYB S4 841004 568 165 403 KYB S4 841002 572 165 407 Hilux strut KYB S4 841008 568 165 403 Prado 150 strut Lovells 646821100 555 155 400 Lovells 64610087A 570 150 420 Hilux strut Lovells 64610087F 570 150 420 FJ Cruiser/Prado 150 strut Monroe D8024 554 125 429 OME Sport 90000 570 130 440 Measured OME Sport 90000 543 130 413 OME Sport 90010 543 130 413 Prado 150 strut Profender 21537 573 138 435 Ridepro ZS167140 550 140 410 Superior SRCP1203F 574 174 400 3” strut Superior SRCP1204F 660 210 450 4” strut TJM XGS Gold 659GE188L 555 135 420 120 strut TJM 4000 XS188L 555 135 420 150 strut Toughdog BM404400 564 139 425 Toughdog BM404600 575 145 430 Hilux strut
Front Coil Data
Code:
Front Coil Free length Spring rate Spring rate Notes mm N/mm lb/in Standard Prado 120 370 580/585 Measured Petrol Standard Prado 120 370 620 Measured Diesel Standard Prado 150 345 780 Measured Diesel Standard FJ Cruiser 355 590/595 Measured Passenger/Driver side Standard Hilux 369 565 Dobinsons data ---------- Dobinsons C59-128 330 102.7 586* Lowered Dobinsons C59-274 350 102.7 586* Lowered Dobinsons C59-134 370 102.7 586* Standard height Dobinsons C59-300 385 102.7 586* Dobinsons C59-302 395 102.7 586* Dobinsons C59-314 405 102.7 586* Dobinsons C59-350 380 127 725* Prado 150 Dobinsons C59-352 385 127 725* Prado 150 Dobinsons C59-354 390 127 725* Prado 150 Dobinsons C59-514 340 790 Dobinsons C59-718 365 127 725* Dobinsons C59-724 370L/375R 127 725* Prado 150 KDSS Dobinsons C59-726 380L/385R 127 725* Prado 150 KDSS EFS TPR-104E 375 650 EFS TPR-104HDE 370 800 H&R X/K 365 675 Ironman TOY055B 380 672 Ironman TOY055C 373 834 King KTFS-101 355 660 King KTFR-101 375 660 King KTFR-101H 385 660 King KTFR-101HD 370 800 King KTFR-101HHD 390 800 King KTFR-101T 405 480-730 Taper, 0-50kg, light bullbar King KTFR-101HT 415 480-730 Taper, 50-100kg, steel bar, winch King KTFR-101HDT 420 500-800 Taper, 100-300kg, steel bar, winch, dual battery King KTFR-121 350L/360R 800 Prado 150 KDSS King KTFS-121 335L/345R 800 Prado 150 KDSS Lovells TFS-118 345 799 Lovells TFR-118 360 799 Lovells TFR-118HD 352 984 Lovells TFR-118EHD 345 1125 OME 883 375 590 OME 884 390 590 OME 885 395 590 OME 886 402 660 OME 887 400 590 Prado 150 OME 888 405 590 Prado 150 Ridepro ZC7134 370 586* Standard height Ridepro ZC7300 385 586* Ridepro ZC7302 395 586* Ridepro ZC7314 405 586* Toughdog TDC974 375 660 Toughdog TDC974H 370 800 Toughdog TDC974HH 390 800 TJM 770FR88IT 375 660 TJM 770FRHD88IT 385 660
Code:
Rear Shock Open Travel Closed Notes mm mm mm Standard Prado 120 574 215 359 Measured GrandeTEMS Prado 120 575 189 386 Measured Standard Prado 150 569 206 363 Measured Standard FJ Cruiser 570 208 362 Measured ------------- Bilstein BE5-A713 580 212 368 Bilstein BE5-A715 595 217 378 #Prado 150 shock P/No 24-238830 Bilstein B46-1478 599 211 388 #LC80 shockP/No 24-014786 Bilstein B46-1478LT 625 245 380 P/No 24-237024 Bilstein 5100 597 218 379 P/No 33-187174 Bilstein 5160 599 223 376 P/No 25-177909 Bilstein 24-217897 610 230 380 # CalOffroad 24-228602 580 212 368 CalOffroad 24-228602 590 210 380 CalOffroad 24-228602 620 240 380 Dobinsons GS59-637 582 232 350 Dobinsons GS59-701 585 223 362 Prado 150 shock Dobinsons GS59-682 630 250 380 LC80 shock Dobinsons GS59-687 680 273 407 LC80 4” shock Dobinsons MR59-50701 605 220 385 120/150 Rear Std Length can be ordered to 615mm by trimming inter Dobinsons MR59-60701 605 229 376 Optional rear Dobinsons MR59-60682 630 ??? ??? Optional rear 60mm body LC100 rear shock EFS 36-5586 583 225 358 EFS 36-5587 615 232 383 Prado 150 shock Ironman 12682GR 618 245 373 Nitro gas Ironman 24682FE 618 245 373 Foam Cell Ironman 45682FE 618 235 383 Foam Cell Pro King 25001-262A 618 215 403 A' in P/no = adjustable King 25001-257A 650 252 398 LC80 shock'A' in P/no = adjustable Koni 82-2523 575 223 352 Koni RAID 90-5404 587 197 390 Koni RAID 88-1689 612 240 372 #LC80 shock KYB S4 845022 570 220 350 KYB S4 845032 602 237 365 Prado 150 shock KYB S4 845004 608 238 370 LC80 shock Lovells 64612548 560 215 345 Lovells LT 64612489 618 253 365 Series 2 Prado 120/Prado 150/FJ Cruiser/LC 80 shock Lovells LT 64612489 615 240 375 Series 3 Monroe D8019 573 210 354 OME Sport 60004 580 224 356 OME Sport 60080 603 235 368 Prado 150 shock OME 60112 580 224 356 OME N71E 620 250 370 LC80 shock OME Sport 60020 625 247 378 LC80 shock Profender 22135 650 255 395 Ridepro ZS117141 582 232 350 Superior SRCP1203R 620 235 385 3" shock Superior SRCP1204R 670 260 410 4” shock TJM XGS Gold 650GE288L 599 221 378 120 shock TJM 4000 XS288L 600 225 375 150 shock Toughdog BM401116 585 225 360 Toughdog BM401118 620 240 380 Prado 120 bushing Toughdog BM401111 620 245 375 LC80/Prado 150 shock Toughdog FC4111 634 249 385 Prado 150 shock
Rear Coil Data
Code:
Rear Coil Free length Spring rate Notes mm N/mm lb/in Standard Prado 120 380 200 Measured Petrol Standard Prado 150 375 210 Measured Diesel Standard FJ Cruiser 385 195 Measured ---------- AMTS 120ABMD 420 280 120 Prado Grande rear airbag to coil conversion, 40-50mm lift, standard weight AMTS 120ABHD 425 300 120 Prado Grande rear airbag to coil conversion, 40-50mm lift, up to 175kg AMTS 120ABHHD 425 330 120 Prado Grande rear airbag to coil conversion, 40-50mm lift, 175kg to 300kg AMTS 150ABMD --- 280 150 Prado Kakadu rear airbag to coil conversion, 40-50mm lift, standard weight AMTS 150ABHD --- 300 150 Prado Kakadu rear airbag to coil conversion, 40-50mm lift, up to 175kg Dobinsons C59-323 375 215* Dobinsons C59-325 420 38.6 220* Dobinsons C59-327 410 47.5 271* Dobinsons C59-329 410 58.3 332* Dobinsons C59-397 460 225 Dobinsons C59-487 430 49 280 Dobinsons C59-443V 470 Approx 53-58N/mm at ride height with some constant load Dobinsons C59-627 420 270 Dobinsons C59-725 415L/430R 38.6 220* Prado 150 KDSS Dobinsons C59-727 415L/430R 47.5 270* Prado 150 KDSS Dobinsons C59-729 415L/430R 58.3 333* Prado 150 KDSS EFS TPR-105E 390 260 EFS TPR-105HDE 390 310 H&R 94127R 395 280 Ironman TOY056B 392 283 Ironman TOY056C 392 356 King KTRS-102 365 260 King KTRR-102 390 260 King KTRR-102HD 390 320 King KTPR-102 410 190-320 King KTPR-102T 435 160-270 Taper 0-300kg King KTRS-102AB 380 240 120 Prado Grande airbag conversion coil, Standard King KTRR-102AB 405 240 120 Prado Grande airbag conversion coil, Raised Lovells TRS-119 380 261 Lovells TRR-119 400 261 OME 895 390 260 OME 896 390 318 OME 897 390 387 OME 889 400 260 Prado 150 OME 898 400 318 Prado 150 OME 899 400 387 Prado 150 Ridepro ZC7325 420 38.6 220* Ridepro ZC7327 410 47.5 271* Ridepro ZC7329 410 58.3 332* TJM 770RR88I 390 260 Toughdog TDC975 390 260 Toughdog TDC975H 390 320
