winch cradle
    The order is chassis, bullbar bracket, winch cradle, bullbar.
      Originally posted by ondaboat View Post
      Does the cradle bolt to car chassie or soverign bar?
      Sent from my GT-I9000T using Tapatalk
      You've already asked this question in this thread
      Just wondering does this winch cradle fit to the bull bar or the chassis as want to fit winch to ARB non winch bar
      Cheers Adam
      Hi Adam
      The cradle is sandwiched between the mounts and the bullbar, each bullbar uses its own mount, so I would seriously doubt if it would fit the ARB. If you find a friendly dealer (good luck!!) they may have one of the old style cradles lying around after the mount recall they could throw in the back of your car instead of the bin, might be able to modify it to suit the ARB. Nothing a grinder, a welder and a PP tech day couldn't fix!!!
      Matt
      The cradle doesn't bolt TO either, the bullbar bolts go through the cradle and into the mount. The cradle is shaped the fit into the back of the bullbar to strengthen it.
      Matt
      waltec
      2003 Prado Grande TD Auto Pearl White
        Howdy waltec
        Obviously as you have shown, I did ask a question, whoops sorry if I have asked it again.
        I guess it wasn't the awnser I wanted. Can't you say "hey buy this cradle and all will be well" but looks like I'm up for a new bar.
        Damm you Arb why do the make 2 bars at basically the same price.
        Thanks for your input Matt
        Regards Adam
          Could someone please post a picture of the winch mount?
            can anyone help us to post some photos of the cradle please? any instruction? thanks
              It's real easy to fit the Toyota winch mount.
              Bullbar recall must be done.
              If u need the recall done and supply the winch cradle and ask them to clean the slab out of the back seat, I'm sure they could take care of it.
              Then u just bolt up your winch.
                Ok so just called Toyota about picking up a winch cradle, they don't stock them anymore and won't in the future. What are my options? Toyota Said get one made?? Has any one got plans or pictures of one? Cheers
                I thought I would be differant and get a silver prado...
                2004 Grande, 4lt petty, Sov front bar, 9000 Lb tigers winch, factory tow bar, Fwd Rec points, Safari Snorkel, Bushskinz bash plates, Austrack roof top tent on Steel RTT rack, Kings awning, ARB under bonnet compressor, Coleman on Demand HWS, IPad with retina on a Ram mount running Hema Navigator, GME TX 3400, Tekonsha P3 Brake controller, and a Stihl 181.
                  They exist under a new part number. PZQ29602WC
                  amts
                  Ninja Poster.
                    why am i not surprised...! the parts bloke...didn't sound too knowledgable!
                    Does anyone have the new part number please?
                      See my post above which I edited to add the new part number.
                        Sorry Amts, some thing strange is going on with my computer!
                        Cheers for the part number, ill try that on monday.
                        after my my last post i kept searching and found another thread that mentioned the new number
                        http://www.pradopoint.com/showthread...h-cradle/page5
                          the cradle isnt hard to mount, but an aftermarket winch needs a few mods to fit the Fairlead Roller t make it fit, the bracket comes with new bolts and fitting instructions, but you will need 2 new bolts for the Fairlead Roller 40mm long. the part number for the winch cradle is PZQ29602WC and got from toyota at $242. hope this helps anyone
                            Can anyone confirm that a VRS V9500 winch will fit the factory cradle.
                            Thanks in advance.
                              Hi guys I got the winch cradle for $220INC got it ordered and came in in 2 days fitted nice with basic tools. The longest part was trying to line the bar back up and finding somewhere to put the control box. Iv got the tigerz11 grande 12000 pound winch install very easy make sure you get the off set hawse it even came with a baintech duel battery setup for $500
                              04 grande, bilstein A712 &A713 kings spring , 3 inch exhaust chip it chip, XGT lightforce, 1 x lightbar, Sov Bar, Tigerz11 Grande winch with rope, Oricom UHF.
