Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
  1. #13
    Rear door lock problem fixed.
    I had the same problem - occasional failure to lock the tailgate when the cargo blind was in use.
    I took it in to Toyota who said it was a known (intermittent) problem. They had a 'fiddle' with it at the time and all was working, but said to bring it back if the problem persisted.
    It did persist and Toyota did fix it ... by changing the lugs on the cargo blind.
    Nearly a week (!) now and no further problems.
    cheers
    Rrob
    UPDATE
    Had a 'failure to lock' again but now know what Toyota did. The rear blind lugs were 'chamfered' so that the rear most flap on the blind (the bit between the lugs and the rear door) can be tilted down about 45 degrees.
    When tilted down, the door locks. If not tilted down, it mostly fails to lock.
  2. #14
    Lurker
    Join Date
    Apr 2012
    Location
    Sydney
    Posts
    27
    Here is the solution.
  3. #15
    Kh lee. Did you get a new rear blind.
  4. #16
    Lurker
    Join Date
    Apr 2012
    Location
    Sydney
    Posts
    27
    Yes, this is new.
    2012 V6 Auto VX
  5. #17
    anyone have any numbers for the cargo blind field fix ?? my local dealer spent 20 mins refusing to acknowledge it existed, then finally agreed that such a field recall existed, but would not tell me what would be done, wouldn't give me its official name, the date, its number, or read the field fix to me.
    anyone else received a nwe blind under exchange/recall/warranty? just trying to get as much info as possible for this with the dealer.
  6. #18
    double post, wont let me delete it
  7. #19
    after a lot of stuffing around at a local dealer (mulgrave) I now have my new rear cargo blind with the cut out at the lock location..
  8. #20
    Hi Gents, I have this problem now and have removed the blind completely and still have the problem that the rear door doesn't lock. Any advice?
    Regards George
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
