Brains TD 150 GXL
    Steps look great?? How did u get?
    [b]Rob[/b]
      Ohhhhhhh steps!!
      Any idea how they'll integrate them into a brush bar?
      2011 150series GXL
        Mods look great. I hear these new side steps will be pretty good when available.
        [SIZE=2][FONT=arial narrow]2011 Crystal Pearl V6 Kakadu / 3M Tint / Prodigy Brake Controller / GME TX3440 UHF / ABR Battery Tray / Piranha DBE180S+ Isolator / Optima D34 Aux Battery / TJM Airtec Snorkel / ARB Colour Coded Deluxe Winch Bar / ARB Underbody Protection / Outback Ideas Recovery Points / Britax XRay 200 HID Spotties[/FONT][/SIZE]
          Ohhhhhhh steps!!
          Wooley,
          The front section (about 20 cm) unbolts and allows for the insertion of the brush bar which bolts in place then attaches to the bull bar the usual way.
            I am very impressed with the design and fitting of these steps. They have also thought of having the brush bars to be easily added or taken off when required. They are also airbag compliant.
              Looks like they've beaten ARB to the post in terms of looks and practicality.
              How do they attach to the chassis? Do they using existing holes?
              2011 150series GXL
                Check out
                http://www.pradopoint.com/showthread...l=1#post321549
                They bolt to the Chassis.
                  Looking good mate - need to go for a drive
                  Pete - 150 Kakadu, 100 and 80 Series Cruisers
                    Once your second addition settles down, perhaps I could drop in and do my 'woman whisperer' impersonation!
                      Welcome any time - and maybe I could learn something from this woman whispering business
                        Spent some time today installing the front camera.
                        I used a front camera shroud from the Kakadu through Toyota and a front camera from eBay. All up cost around $40 for the two items.
                        It's connected to the replacement Head Unit from Extreme Electronics. To get the front camera to show you just press the F-Cam button. To turn it off you press the button again. The camera gets a power feed from the head unit which only powers the camera when the button is pressed.
                          Much better view than mine!
                          Same bar, same spots and whilst mine is still somewhat useable yours is a 100 times better.
                          Looks great.
                            Maybe Toyota should get me to do their camera setups.
                              Now you just need to be able to hook that feed up to a flash drive and you'll have all the evidence you need.
                              LFaR.
                                Looks great.
                                The Kakadu front camera is a verrryyy wide angle lens (I'd reckon getting close to 180 degrees). Displaying this on a standard aspect ratio screen means some image manipulation is required to make it fit properly.
                                In addition anything in the way or just a bit of to the side will show up real bad,and standard ratio cameras will look better. That's why I'm getting ARB to relocate my camera to the slot at the top of the Deluxe Winch Bar (I'm not putting a winch in at this point in time) when my bar turns up.
                                Michael
