Prado 150 roof rails
  • Prado 150 roof rails
    Roof rails and fixings to suit a 150 GXL.
    I have fitted a new roof rack and no longer need these.
    All brackets and bolts provided.
    Condition = Good. Was on vehicle for about 1 month only.
    Make a reasonable offer via PM
    Local pick up preferred but you can organise your own courier to pick up if you like.
    Si & Rae
    [/CENTER]
    Are they the same as the 120 rails? They look very similar, if so there are a couple of posts in the wanted section with people chasing 120 rails.
    Justin
    2005 120 Series 3.0 TD Auto, OME suspension, Sovereign bullbar, IPF 900XS driving lights, Projecta dual battery system, ARB roof rack, Bridgestone D694 tyres, GME UHF, Custom rear drawer with ARB fridge slide and Waeco 60lt fridge.
      mmm, not sure. I am pretty sure that the 120 rails are a bit stubbier but I would have thought the mounts might be the same. Knowing toyota, that would probably not be the case though.
      [/CENTER]
        No, 120 and 150 rails are not compatible to each other.
          Bump
          These are still sitting in the back room.
          [/CENTER]
            Good to know. Was going to chuck them on Gumtree as well.
            [/CENTER]
              This item is now sold
              [/CENTER]
