The website will be up and running within the next day or so with a full list, but before that; here is some info on the one that always causes the most controversy!
Recovery points
In the minimum vehicle requirements we have set you will see that we have specified “suitable” recovery points. Given the controversial nature of recovery points we will offer the following as a guide to what the committee believes to be suitable!
Original equipment tie down points: these are suitable for towing only. They are not suitable for snatching or winching.
Outback Ideas recovery points (or similar) when used with a bridle are considered suitable for most recoveries including snatching and winching. These recovery points must be attached with minimum grade 8.8 bolts.
ARB bullbar loops when used in conjunction with a bridle are considered suitable for most recoveries including snatching and winching, high tensile bolts with a minimum grade of 8.8 should be used on these as well.
Towbars are considered suitable for most recoveries including snatching and winching, The use of a recovery hitch is needed for winching, and is also advisable for snatching. If using the hitch pin to attach the snatch strap this must be a minimum of grade 10.9 metric or grade 8 imperial. The towball MUST NOT be used for recoveries under any circumstance.
Rated recovery hooks (10,000lb) securely attached to the vehicle chassis or on solid mounting points that are securely attached to the chassis using minimum grade 8.8 bolts or grade 5 if using imperial bolts; are considered suitable for most recoveries including snatching and winching, especially when used in conjunction with a bridal.
These requirements are NON-NEGOTIABLE! If you attend this event without meeting these requirements, you will not be included in GTG activities.
See Ya in SA The Committee
Recovery points
