G'day Pradopointers , Rocking Horse ... i know but I'm looking for a Genuine winch cradle for a Sovereign Bullbar . Kind regards to all , Fletch
WTB . 120 series Sovereign Bullbar Winch Cradle
Can still buy new from Toyota. When they did the recall for the sovereign bar they also had to be fitted with a new winch cradle as the new brackets are different and didnt suit the old winch cradle. When I had my recall done (last year not that long ago) they asked wether I had a winch or not as they would have had to fit up the new cradle as well so would require extra time for fitment. I dont have one fitted to mine. Presume you would have known about the recall ?? Possibly not, I only found out about it from this website, never got a letter or anything from RTA or Penrith Toyota. They were replaced due to cracking/stress fractures.......Cheers SteveFace lift 150 Prado V6 auto. No mods yet
Hi Peter ,
Thanks for that part number mate . Toyota here in Cairns are saying they cant be got , but after reading the older posts here on PP i see that some members have aquired a cradle as little as 2 months ago . I will go in and see them again armed with the part number you have provided and tell them to have another look . Kind reagards Fletch .
Gday bigalthomo ,
Mate , armed with the part number supplied by peterpilot i have ordered one through Pacific Toyota here in Cairns for $203.00 inc gst . THEN upon inspection they worked out that my ex-govt beast has never been in for the bullbar mounts recall , so they're going to fit it for me with the new mounts ..... heh , heh , heh . Oh, what A Feeling
Hi Guys,
Just out of curiosity, would someone be able to let us know how heavy of a winch I can go with the genuine sovereign bullbar? Also, if you have a sovereign bullbar and have a winch fitted, which winch did you choose, what else do I need to get in order to fit a winch and do I need to have my front suspension changed to fit a winch?
Buzz
Hi buzz,
I have an ironman 9500 winch fitted to sovereign bull bar. I noticed when installing mine that there s a sticker that states no more than 9500 lb winch. I know others on PP have put 12000 lb on theirs. The best test I have done with mine was to winch myself up a muddy slope whilst towing a tonne of firewood which it struggled but still made it( single line pull) . I also use a redarc to bridge both batteries whilst winching. The winch fits snugly inthe cradle with the control box mounted right behind the winch. There is not much room for the main negative cable but it does fit. The control cable only just reaches into the cabin, but I always use the remote one with no hassles.
Phil06 120 GXL 1KZ-TE man, modified exhaust, K&N, OME 2",spacers, Sovereign BB, Safari Snorkel, Hella 4000, 33" muddies, ARB 60L fridge / slide ,custom rear drawer, cargo barrier and table, Ironman 9500lb Winch, TJM underbody guards, DIY Radiator bash plate, Outback Ideas recovery points, AJ's sliders, CKMA12, lockers, ext rear breather, UHF, dual batt, SBi12, ARB alloy roof cage, ARB side awning...
I have Ridge ryder 12000 with synthetic rope .Have mounted the control box on the left side behind the grille on the support bracket for the Bar.
other things you may need depends on the tyope of winch you end up putting in but as others have said on this topic previously maybe longer mounting bolts due to the thickness of the plate as the standard bolts are just not long enough..
do a search for sovereign winch and as attached are just 2 of many previously submitted topics.
hope that helps
http://www.pradopoint.com/showthread...overeign+winch
Guys if anyone interested a Roo destroyed my Driving Lights last weekend and made just enough of a tear in the sovereign bar
(BTW Rallye 4000's Bullet proof mount causes a tear in the bar but didnt damage outer case !!)
that i have been able to replace my Sovereign Bar with anew ARB Steel one on insurance .
Hence i have a once fitted Never used Cradle that I'm looking to get rid of as well as a once use set of AMTS's awesome
radiator plate for the Sovereign bullbar .(Andrew coming for more under body protection soon)
Anyone interested i can show the pics no damage to cradle just enough for insurance.
I'll have in my hand by next Thursday PM or call syd 97614236
Update - Cradle and Bar both gone as is my AMTS Bach plate2011 GXL diesel , ARB Steel winch bar, Runva 11000 winch , 9" hid , 22" light bar , sliders, , Eaton E-locker rear , 2" OME lift, Poly bags , Piranha dual battery , 285*70*17 BFG AT/TA
I'm interested in the radiator plate as long as no damage and is still straight . That's the one that fills that huge gap between bottom of bar and air con condenser (radiator) ??.... Cheers SteveLast edited by Steve M; 05-09-2014, 08:26 AM.Face lift 150 Prado V6 auto. No mods yet
Steve - change in timing sorry - for some reason my New deluxe ARB bar is going to take almost a month to be available . I would not be able to get it ready till oct 7-9 . understand if this means you are not interested sorry - only told on Friday so a little dirty ..
Steve i'll take photos in (now 10 days - bar coming form melb and i'm at farm next week )so you can see . and yes its the gap between the bar and basically under the engine about 30 ish cm long . cheer Nige2011 GXL diesel , ARB Steel winch bar, Runva 11000 winch , 9" hid , 22" light bar , sliders, , Eaton E-locker rear , 2" OME lift, Poly bags , Piranha dual battery , 285*70*17 BFG AT/TA
