Ideas for a shovel holder for suit ARB rack?
  • Ideas for a shovel holder for suit ARB rack?
    I have just fitted an ARB style 3/4 length steel roof rack. In my preperation for a Cape york trip in July. I am after a shovel holder to attach to drivers side. I have found one which is both shovel holder and hi lift jack holder.
    but I only want the shovel holder. Any ideas and where I could get one in Brisbane
    Graeme
    1998 Gxl, Ironman Bullbar,12,000 Winch. Rear ARB Locker,Arb Compressor, OME 2" Lift, Light Force Driving lights Roof 3/4Steel Rack Icom UHF, Kenwood TS50 HF Band Ameteur Radio, Yaseu 2m VHF Ameteur Radio, Diff Breathers
    Pretty sure prorack or a similar brand makes them. Bcf sell prorack brands.
    2012 Suzuki jimny 50mm lift, 215/75/15 hankook muddies, 30 inch dual row light bar, gme UHF, arb compressor, rola roof rack, ironman awning, projecta dual battery system with yellow top optima, evakool fridge freezer and arb air locker this month!
      Get some quick fists
        Is it possible to padlock the quick fists so the shovel is secure and locked? ...possibly by drilling a small or something similar.
        I am also interested in finding a shovel holder only for my roof rack.
        [b]Black 2007 Chrysler 300c 5.7L V8[/b]
        SOLD - 1997 Toyota Land Cruiser Prado GXL
          Hi Graeme,
          apart from the Kaymar option (which I assume you've already had a look at)
          Try getting the Rhino shovel holder and put a longer screw through the base of it and then either drill through the roof rack and put a nut on the other end or get some sort of clamp mount and attach the bracket to that.
          Loz - 2007 GXL D4D Auto White
          ARB Deluxe Winch Bar, 2" OME Lift, ARB On-Board Air, Safari Snorkel, GME TX3440 UHF, GME AE4018K1 antenna, Redarc/Exide ED5 dual battery system, ARB 47L fridge, Cooper AT3's 265/70/17, LeighW's voltage booster, Lightforce 240XGT's, Outback Solutions Drawer Systems
          [url=http://www.pradopoint.com/showthread.php?20863-Loz-s-120-GXL-D4D-Prado&highlight=loz%27s]My Rig Build-Up[/url]
            Nope, but you could drill a hole in the shovel blade and use a wire cable locked to the roof rack. I don't like drilling holes in handles.
              hi guys. I picked up the rhino rack shovel holder, and have fitted it to a TJM rack. They are a great little holder and have held up to 1000s km of outback corrugations and the odd beach run. D4D thats a fantastic idea to secure shovel from undesirables, will have to get on to that ASAP.
Name:	Copy of IMG_0068.jpg
              96 3.4 GXL, 2" lift, Poly airs in rear, 32" BFG muddies, Lightforce 170's HID's, TJM rack, Awning, Twine on board shower, GME uhf, Dual batteries & monitor, Storage system, ARB fridge, LED rear lighting, Safari snorkel, Brown Davis bash plate, Ironman winch bar, Runva 11xp winch, Roadsafe recovery points, ARB compressor, Tyre dog monitor, AJ's sliders, Hema hn6. The to do list is getting shorter.
                [ATTACH=CONFIG]5532[/ATTACH]
                Nice one Playdoh96. Im presuming you used these things? - http://www.ebay.com.au/itm/Rhino-Roo...ht_2742wt_1012
                Guessing you drilled a hole in the back of the "flat" part of the mount then bolted em up? Im thinking of doing it this way.. May work for you as well GraemeJ
                -- Edit --
                Just bought a pair of these off eBay, will see how they go
                EasyCompany24
                  That's what I did today, I have the full length ARB steel rack. I just drilled the holes in the flat sections and screwed the rhino holders in. Put down a rag to catch the swarf, and give a good blow with the compressor to clear the area. Also a bit of paint to protect the raw steel.
                  Regards, Heath.
                    Yeah that's the ones. Didn't know u could get lockable ones now. Mounting, I had to cut up some 3mm plate and fit that on the inside of rack. TJM racks have 2" hole in the uprights unlike ARB solid ones. Have mounted awning the same way with no trouble to date (touch wood!!!)
                      I have a set of single shovel holders - were attached to my Alloy roof rack but recently changed them out for high lift Jack/ Shovel mount. Were bolted through front and rear legs of the roof rack. If interested can email photo and $$
                        Thanks for all the replies guys.Just finalizing everything for our cape trip in July
                        Graeme
                          Those Rhino Rack Shovel Holders are pretty good; they hold the shovel securely and safely. ...got mine up this morning.
                            Looks good EasyCompany24!!! How do you rate the locking side of these clamps? Dose it lock the handle solid, or lets it free wheel? Just thinking of up dating to the lockable ones.
                            Thanks Kris
                              Thanks Kris
                              Thanks Playdoh96. The locking aspect of the holders are pretty good; nice and strong. Once you tighten them up and lock it, the knob itself spins freely - thus stopping the knob from gripping onto the thread and being able to undo. I presume you can still use some sort of shifting spanner to grab onto the thread itself and undo it; but what are the chances of someone walking around with a shifting spanner in their pocket. The lockable ones are quite good. I'd love to have another locking knob... just for extra security
