Results 1 to 7 of 7
  1. #1
    Lurker
    Join Date
    Oct 2010
    Location
    Dysart, Central Qld
    Posts
    2
    ABS Light flashing
    Hi everyone,
    The ABS light in my 120 comes on when doing its self check then starts flashing. If I turn the key off then back on & let it do it's thing again it goes out and stays out. Have had the car back to Toyota to check it out but they can't find anything wrong. Has anybody else had the same problem?
    Matt.
  2. #2
    Lurker BARRLIND's Avatar
    Join Date
    Sep 2007
    Location
    Melbourne
    Posts
    25
    Hi Matt
    I seem to have the same problem. After the self test the ABS and VSC/TSC lamps start flashing and when ignition turned off and back on they retest ok. Mainly happens when vehicle cold but can happen during day if been standing for sometime.
    Baz
    Bazza
    ___________________
    08 GXL D4D Auto
  3. #3
    Administrator Piggy's Avatar
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,716
    Blog Entries
    4
    Check alignment on the abs sensors on each wheel.
    Check no mud or gunk in the abs slots.
    Check plugs on abs cabling ok.
    Check for stone damage on abs sensors cable.
    All can create an intermittent issue.
  4. #4
    Senior Member barryswanson's Avatar
    Join Date
    Feb 2011
    Location
    QLD
    Posts
    362
    Also be aware that ABS does not work when the light is flashing.
  5. #5
    theres also a little sensor under centre consol just behind gear sticks, check the plug, mine had a similar problem and tried it first and it fixed it. .
  6. #6
    Lurker
    Join Date
    Jul 2017
    Location
    Brisbane
    Posts
    2
    Quote Originally Posted by 05pilbara View Post
    Hi mate can you please specify where is the sensor ? As my Prado abs light is flashing and I have tried every thing . Your help will be great ..
  7. #7
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,716
    Blog Entries
    4
    Quote Originally Posted by Mrprado86 View Post
    there is also a little sensor under centre console just behind gear sticks, .
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
