Antenna base: with or without spring
Last edited by D4D; 03-06-2012, 10:51 AM.[url=http://www.myswag.org/index.php?topic=12264]My Prado[/url]
A ground independent antenna is electrically superior - where you mount it is still important though as shielding from the vehicle will affect performance. If you mount it half way up the back door, the antenna performance will be pretty good in the arc behind the vehicle and somewhat less in the forward arc.
Soz2010 GXL Diesel, Cooper AT3's, TJM T13, Scanguage II, Sandgrabba's, Ridepro springs and shocks, dual battery, Icom 440N, Rhino pioneer tray...
hey amts do you intend on leaving the antenna fitted full time looking at your vid showing the shelf you should have plenty of room to keep the base on without the antenna fitted I have a Gme with spring base and the base is 100mm high.
the cables are hard wired to the base its easy to figure out install, once you get it you'll see.
If you are able to feed some spare cable into the spring to allow for flex.
if you like the idea of the knockdowns have a look at theuteshed.com.au for another alternative
pete
Andrew, dont worry about that guy on PP called 'amts'. - His products are carefully engineered for performance and reliability.
Come see me and i'll sort you out with a couple of chopping boards, jigsaw and a drill...Cheers
Originally posted by wooley View PostI've heard they're poorly designed by some BAE bloke... That's a bachelor of arts and equine studies for all of you playing at home.
Originally posted by 120D4D View PostAndrew, dont worry about that guy on PP called 'amts'. - His products are carefully engineered for performance and reliability.
Originally posted by amts View PostThat should read "I've heard they're designed by some poorly paid BAE bloke who needs to feed 4 kids and now 2 guinea pigs ..."2011 150series GXL
I don't. The missus bought it. I suppose they're cheaper than having more kids.
On more exciting news, the antenna(s) have arrived. Unfortunately, the base is nearly 310mm long. I now have 3 options:
1) swap parking positions in the garage with the missus' car
2) fit antenna at the spare tyre
3) fit to roof rack and fabricate a knockdown bracketLast edited by amts; 27-06-2012, 11:59 PM.
Originally posted by amts View PostI don't. The missus bought it. I suppose they're cheaper than having more kids.
2) fit antenna at the sapre tyre
3) fit to roof rack and fabricate a knockdown bracket2011 150series GXL
