Well it seems I enquired and then lost track. I have sent you an email Andrew to order one. Hope you still do them!
AMTS radiator bashplate for 120 Sovereign bullbar
2005 GXL KZJ120 3.0TD. Goodies: 2" TJM XGS Gold Suspension Lift, Safari Snorkel, TJM Underbody Protection, Sovereign Bullbar, AMTS radiator guard, spare wheel spacer & soverign bar LED lights, Runva 11XP Winch, Front Recovery Points, BRC Quad Breathers, Rhino-Rack Pioneer Platform, IPF spotties converted to HID, Drifta Drawers D2D-WT, Autosafe Cargo Barrier, Uniden UHF, 265/70/17 BFG AT's.
Originally posted by djnapkin View PostAny idea if this would work with TJM underbody protection. Does this have any effect on heat? I.e. less air to radiator means running a bit hotter?
I'll try and post a pic when I've time.Last edited by macaroon1; 09-01-2014, 03:50 PM.[SIZE=1]03 TD 120 Grande, L&R weathershields, f&r deflectors, Sov bar Amts rad b.pl, TJM front B.P, Uniden UH7760NB Kaymar LED worklight, ARB 47l, lifestyle rack & Milford C. Barrier, 9500llb Superwinch, IPF 900SR spots, T. Dog 40mm adj shocks/struts, coils, airbagman OA6011 airbags, 2.75" Beaudesert exhaust, 300w inverter, 1L Catch can,outback rec points, R.R awning, dual batteries redarc SBI12 Cooper LT A/T3's 265/65, Safari snorkel, Hilux jets, Brains TG150, Leigh's booster diode [/SIZE]
How does the plate go when a winch is installed?
Thermally, it is pretty much the same as any other bullbar on the market where there is a plate in front of the radiator.
Thanks AMTS! Got mine installed on the weekend. Fits beautifully with the winch bracket and the TJM bash plates. Only drama I had is that when removing the TJM bash plates (first time) I snapped one bolt flush and discovered another was already snapped and was never repaired thanks the the knucklehead at my local shop over tightening and using mild steel bolts. Drilled out and tapped a thread in both though not entirely happy with the result. Can't speak highly enough of AMTS's plate though!
Sent from my GT-P5110 using Tapatalk2005 GXL KZJ120 3.0TD. Goodies: 2" TJM XGS Gold Suspension Lift, Safari Snorkel, TJM Underbody Protection, Sovereign Bullbar, AMTS radiator guard, spare wheel spacer & soverign bar LED lights, Runva 11XP Winch, Front Recovery Points, BRC Quad Breathers, Rhino-Rack Pioneer Platform, IPF spotties converted to HID, Drifta Drawers D2D-WT, Autosafe Cargo Barrier, Uniden UHF, 265/70/17 BFG AT's.
I reckon the cost will be more than $120, but I can attest to the quality and value as being excellent!
Send AMTS a pm and he should be able to hook you up2009 White KDJ120R Manual fitted out for family camping and touring - See my Rig Build at [url]http://www.pradopoint.com/showthread.php?27887-Smithy-s-Rig-Build[/url]
cool thanks guys
email sentLast edited by Gypsy4wd; 27-06-2014, 01:15 PM.[SIZE=5][I]You take the highway..I'll take the by way[/I][/SIZE]
