Which Rear steel bumper to get?
    Originally posted by MDST View Post
    What you have to modify? The rear bumper is attached to the body and goes up when bodylift is installed.
    The original plastic bumper connects to the body, but if you buy one of these steel rear bars, they will most certainly connect to the chassis and leave a gap. I already had to lift my front bull bar for this reason.
      Yeah, Glen is right.
      The Ori plastic bumper is attached to body, while the aftermarket steel bumper attached to Chasis.
      So, when you raise the body, the bumper will give the gap,while will look quite abnormal.
      But mount to Chasis is good as the tire and other load can pass to Chasis then body.
        I have a few problems that I can see with the ACC Viper bar, firstly, the bar is not suited to models with flared wheel arches, secondly, you have to get a new tow bar that will fit with this bar as it sits very high, and thirdly, you will need to fit new mudflaps, this needs to be taken into consideration if you plan to buy one of these bars, as it will add to the overall price of getting the new bar fitted on the vehicle properly.
          Croozza is right!! However these photos are only to be taken as examples!!
          Prado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
            The tow bar is actually an advantage IMO, not a drawback. The other issues, well, we can't simply go by the photos presented, they'd need to be confirmed.
            However, I did read on another forum today, of a Prado owner having a lot of issues installing the MCC bar... about half way down the page...
            http://www.4wdaction.com.au/forum/vi...?f=75&t=123614
              The thing is, a normal towbar will sit too low, and look out of sorts, so you will need to get a custom job done. All this adds to the overall $$$$$ spent, not many people are willing to do that cause then you do not have a tow rating, and in most cases, if you still need to tow, then this bar is not suitable for you, as nice as it looks.
                WTF? that guy needs a drug induced coma to come back to reality! I had a standard cast iron Toyota bar which meant a small, I repeat small mod would be required. Instead I took the opportunity to upgrade to a Hayman Reece which needed no mods. The bar has been updated again to better accommodate Toyota standard towbars I believe.
                mlc
                  Look this rear custom made bumper:
                  http://forum.ih8mud.com/90-series-te...rig-build.html
                  I liked a lot!
