Thank you very much amts for the time you have taken to share this method. My mate and I fitted Dobinsons GS59-221 front shocks C59-314 front springs (heavy duty) Dobinsons GS59-701 Rear shocks and C59-325 rear springs to my 04' 120
Rears were really easy. Just have to disconnect sway bar ( I hope that's what its called) if you are installing new rear springs. I found it easier anyway.
Front was not quite as easy but the instructions were followed to the t and all went really well. Have to love saving $400 dollars installation especially when I want to learn more about the Prado.
My dobinsons bullbar has not yet been powder coated so it has not been installed or the dual battery system I want to install so it's sitting up as a fair bit in the front end. Here are some specs on before and after measure from middle of wheel to wheel arch.
FRH : 515mm (Before) #FRH: 600mm (After)
FLH: 510mm (Before) FLH: 600mm#(After)
RLH: 545mm (Before) RLH: 595mm#(After)
RRH: 545mm (Before) RRH: 595mm (After)
Meausured from Axle centre to wheel arch
Thanks again very much amts for the instructions.
Jamie
Jamie
