Is there a 2din mounted multimedia head unit that you can plug a scam gauge or similar obd2 device for displaying engine diagnostic data?
Viewing obd2 data
Have a dig around with google and I am sure you will find some entertainment units with a built in OBDII interface in a double din mount. Whether they support the Toyota codes will be the biggest issue.
There seems to be some fairly cheap stuff out there that will give you OBDII interfacing.
http://www.ecrater.com.au/p/15777363...-road-carnival2011 150 GXL D4D Auto White, ARB Deluxe Bar, Windcheatah roof rack, Warn 9000 winch, IPF Spotties, Mounted ARB Compressor, GME TX3540, Codan 9323 with 9350 Auto Tune Antenna, Kaymar rear spacer & HF mount, OME Sport Shocks & Springs, Safari Snorkel, 5T Rated recovery points, Exhaust Jack, BFG AT tyres, Maxtrax, Scangauge.
[/CENTER]
